-   -   How do I drain my water heater? (http://www.diychatroom.com/f7/how-do-i-drain-my-water-heater-83257/)
HVAC_NW 10-07-2010 04:05 AM
I need to remove my water heater, but I don't know where I would drain it to. It is in the laundry room next to the washer sitting at floor level and I don't have anywhere low enough to drain to.
Washer drain house is in the wall.
Could I use a garden hose attached to the bottom, then shove it down the washer drainage so that the tip is lower than the bottom of water heater, then open the drain, a faucet, then shut off water supply to water heater and hope that water will siphon out?
If I recall correctly, as long as there is water already flowing and point of drain is lower than the water level, having an inverse U higher than water level doesn't affect the siphon.
majakdragon 10-07-2010 06:31 AM
Do you have a shower or an outside door nearby? I always run a garden hose to one of these areas. Siphoning could be a long process.
Just Bill 10-07-2010 06:52 AM
I use a small pump to drain water heaters. It will push water uphill and does it faster. Big box stores have small pumps for not too much money.
AllanJ 10-07-2010 10:13 AM
Open hot faucets upstairs. Take the drain hose and put it into the laundry tub or even into the washing machine. In the case of the latter you would have to start the spin cycle once or twice to empty out the washing machine before it overflows and be careful you don't get the hose and the agitator tangled.
You will drain the tank reasonably quickly down to the level of the hose as it loops over the side of the tub or machine. If you are lucky you will drain the tank down to the level of the end of the hose inside the tub or machine.
If the flow stops, take the hose out, lay the end on the floor, and when water comes out put your finger on the end and put the hose back into the tub/machine. After two unsuccessful tries of this, go on to the next paragraph.
Now there is only a small amount of water left in the tank that has to be emptied out a bucket at a time. Instead of turning the little valve under the tank so many times which can wear it out, leave the hose on and lift the end of the hose up and hang it on the pipes on top of the tank between bucketfuls.
TheEplumber 10-07-2010 04:25 PM
199 Attachment(s)
Simply hook up a air comp to the T&P tapping, close the coldsupply valve, hook up hose and place end at desired discharge location. Open the boiler drain and turn on compressor. It doesn't take much air. Works good if you have sediment too.
HVAC_NW 10-07-2010 06:45 PM
Washing machine, then a five gallon bucket it is. I'll get it light enough to move it, then I'm just going to let her pee away once I get it outside
HVAC_NW 10-14-2010 10:08 PM
I don't have a compressor. Can I hook up a can of R-22 refrigerant instead to push out the water?
AllanJ 10-15-2010 09:22 AM
No!
Wasteful, and it won't last long enough. And get poison gas (yes, Freon is poisonous to breathe) all over the place.
If so much sediment had accumulated inside the tank that the bottom drain valve doesn't work at all, a few squirts of air up the drain valve from a tire hand pump may be enough to loosen things up.
fabrk8r 10-15-2010 09:27 AM
You're kidding, right?
HVAC_NW 11-10-2010 04:00 PM
Drainage went fine. The bottom thing was clogged, however I was able to punch out the heat trap on cold side and attach long hose leading outside with the end lower than the bottom of water heater. I initiated the water flow using an inert non-flammable gas that shall remain unnamed into the hot side. I got the siphon going and water siphoned out up the dip tube and after about an hour it drained fine.
chayce 11-10-2010 04:15 PM
Thanks, this is the best chuckle I've had all week!
