Old 04-26-2012, 12:24 PM   #1
How do I cut excess acrylic shower panel?
The shower panels I installed are wider than they need to be. Instructions that came with it says to cut it to the proper width with a knife but this doesn't work at all. Barely makes a scratch. Can I use a jigsaw or something? I need a clean cut or it will look like crap. I e-mailed the manufacterer but didn't get a response.
pennywise is offline   Reply With Quote
Old 04-26-2012, 02:04 PM   #2
you can use a jig saw with a very fine blade - a metal blade or similar
The whole sheet should be supported, and jig saw should be guided.
Or, you can get a carbide scoring knife and try that way.
Think of cutting it with a jig saw and the hiding the cut edge under a trim or something. They sell nice plastic trims at the orange store.
BNTHERE is offline   Reply With Quote
Old 04-26-2012, 02:08 PM   #3
Thanks BNTHERE. It just annoys me that they make it look so easy in the instructions only to find out it doesn't work that way!!
Old 04-26-2012, 02:11 PM   #4
you are welcome.
I know...if you are going to use jig saw, make sure you lay down the acylic sheet on a flat surface so that the cut area is completely supported. guide the jig saw so that it makes a straight cut - measure twice, cut once and cut slow.
Old 04-26-2012, 09:59 PM   #5
protect your material if using jig saw..or it will mark it.....bigtime...
Old 04-26-2012, 11:39 PM   #6
if acrylic is it abs with acrylic cap usually 1/8" thick and bendable or is it resin acrylic that is 1/4 "to 1/2" thick and more brittle
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 03:09 AM
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 11:03 AM
Acrylic shower wall panels. sukhenkoi Kitchen & Bath Remodeling 5 02-18-2011 07:01 PM
Installing acrylic shower base onto concrete floor Dawna106 Flooring 0 10-15-2010 06:42 PM
