Old 03-31-2010, 11:58 AM   #1
How do I convert an enamel wash basin into a sink?
I'm not even sure if this is possible or not but, I was wondering if there was a way to convert an old enamel-coated metal wash basin (white with blue around the lip) into a bathroom sink? How would I drill the hole without wrecking the enamel and how should it be affixed to the vanity (I'll be using an antique wash stand)?
Sarahipp is offline   Reply With Quote
Old 03-31-2010, 12:09 PM   #2
A hole saw "may" work, but there is always the chance that the enamel could chip. You would need to go very slowly when trying to drill the hole. I would also suggest using Plumbers putty to form a dam around the hole area and filling it with isopropyl alcohol to prevent heat build-up while drilling. Good luck.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Chip in Enamel Kitchen Sink Repair girlscandoittoo Appliances 5 10-06-2009 07:29 PM
Sump Basin Install Considerations Fire4Effect Building & Construction 3 08-05-2009 05:30 AM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
Anchoring a pedestal sink basin - stud or drywall anchor? AdamB5000 Drywall & Plaster 3 11-24-2008 02:42 PM
Caulking around kitchen sink deeaa Remodeling 8 07-13-2008 04:12 PM
