How Do I Bond Pvc Pipe To Cast Iron - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-03-2011, 07:29 PM   #1
how do I bond pvc pipe to cast iron
Old house, replacing toilet, plastic offset has to go into old cast iron pipe, whatss them best way to bond it ? Thx !
Updated with pics! thx for responses
1badmf is offline   Reply With Quote
Old 08-03-2011, 08:12 PM   #2
DIY staff
Rewards Points: 7,174
If you have a 'hub'--use a rubber dough nut----
If you have a cut pipe--a rubber Fernco type boot with hose clamps works well.
Post a picture if you can that will get you the most accurate advice.
Old 08-04-2011, 12:32 AM   #3
Rewards Points: 352
Thumbs up
leading it in is always a ton of fun
plumberinlaw is offline   Reply With Quote
Old 08-04-2011, 06:50 AM   #4
DIY staff
I've fixed a few shower drains when someone tried that.
Old 08-09-2011, 03:31 PM   #5
pics....
how do I bond pvc pipe to cast iron-imag0061.jpg   how do I bond pvc pipe to cast iron-imag0062.jpg   how do I bond pvc pipe to cast iron-imag0063.jpg   how do I bond pvc pipe to cast iron-imag0064.jpg   how do I bond pvc pipe to cast iron-imag0068.jpg
Old 08-10-2011, 01:15 PM   #6
To the top
Old 08-14-2011, 11:09 PM   #7
Hmmmm
Old 08-15-2011, 12:16 AM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 358
If you use that flange, you need to bust out the floor, lower the CI pipe to the proper height and use a PL x CI no-hub band to join the flange to the pipe. Then replace the removed concrete and anchor the flange to the floor
Why an offset flange?
Old 08-15-2011, 05:06 PM   #9
Old house, the toilet is at a wierd distance from wall , whats would you suggest to just to install toilet easiest
Old 08-15-2011, 10:46 PM   #10
These toilet replacement flanges; manufactured by Oatey, are made to push into a 4" cast iron drain or plastic pipe and seal against the internal diameter with a rubber gasket. Although they make a flange that fits inside a 3" pipe, they are not permitted because they reduce the internal diameter.
You can try this, I have never used one before but I have seen them. It is difficult to tell the size of pipe you have there, it looks like 4" but the flange you have looks like 3". Just a suggestion.
Dougtheplumber is offline   Reply With Quote
Old 08-15-2011, 10:57 PM   #11
DIY staff
How far from the wall to the center of the pipe?
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 10:35 AM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 02:42 AM
Leak in Cast Iron? Pipe under toilet... terrapin88 Plumbing 11 11-19-2009 06:54 PM
pouring concrete around cast iron pipe? walkman Plumbing 1 10-16-2009 11:04 AM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 09:20 PM
