-   -   how do I bond pvc pipe to cast iron (http://www.diychatroom.com/f7/how-do-i-bond-pvc-pipe-cast-iron-112877/)
1badmf 08-03-2011 06:29 PM
Old house, replacing toilet, plastic offset has to go into old cast iron pipe, whatss them best way to bond it ? Thx !
Updated with pics! thx for responses
oh'mike 08-03-2011 07:12 PM
If you have a 'hub'--use a rubber dough nut----
If you have a cut pipe--a rubber Fernco type boot with hose clamps works well.
Post a picture if you can that will get you the most accurate advice.
plumberinlaw 08-03-2011 11:32 PM
leading it in is always a ton of fun:thumbsup:
oh'mike 08-04-2011 05:50 AM
I've fixed a few shower drains when someone tried that.:laughing:
1badmf 08-09-2011 02:31 PM
6 Attachment(s)
pics....
1badmf 08-10-2011 12:15 PM
To the top
1badmf 08-14-2011 10:09 PM
Hmmmm
TheEplumber 08-14-2011 11:16 PM
199 Attachment(s)
If you use that flange, you need to bust out the floor, lower the CI pipe to the proper height and use a PL x CI no-hub band to join the flange to the pipe. Then replace the removed concrete and anchor the flange to the floor
Why an offset flange?
1badmf 08-15-2011 04:06 PM
Old house, the toilet is at a wierd distance from wall , whats would you suggest to just to install toilet easiest
Dougtheplumber 08-15-2011 09:46 PM
http://www.plumbinghelp.ca/images/oa...eplacement.jpg
These toilet replacement flanges; manufactured by Oatey, are made to push into a 4" cast iron drain or plastic pipe and seal against the internal diameter with a rubber gasket. Although they make a flange that fits inside a 3" pipe, they are not permitted because they reduce the internal diameter.
You can try this, I have never used one before but I have seen them. It is difficult to tell the size of pipe you have there, it looks like 4" but the flange you have looks like 3". Just a suggestion.
oh'mike 08-15-2011 09:57 PM
How far from the wall to the center of the pipe?
