How Do I Attach PVC To Metal Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-14-2009, 09:14 AM   #1
How do I attach PVC to metal pipe?
Hi, I'm trying to replace a broken piece of what I belive is cast iron pipe with new pvc on a bathrrom sink. Not positive its cast iron, but the piece that broke was about a 5 inch long connector piece threaded on both ends. One end to the main pipe and one end going into the plastic under the sink. The threads from the connector piece came apart and it was very corroded. So now I need to install new pvc but I'm not sure how to attach it to the metal pipe. Any thoughts?
brianhowell2 is offline   Reply With Quote
Old 07-14-2009, 09:21 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You describe what is most likely a piece of galvanized pipe that was screwed into a T on the drain pipe. You just need a male threaded PVC adapter (with 2-3 flat wraps of teflon tape wrapped clockwise only on the threads as the threaded end faces you) to screw into the T. Clean up the threads on the T first.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-14-2009, 09:31 AM   #3
thanks alot
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 02:53 PM
1/2" pipe fittings don't fit old pipe- PLEASE HELP carjack Plumbing 1 05-21-2009 04:22 AM
Newbie Solder Question SteveSmith98 Plumbing 9 01-15-2009 10:50 PM
stuck iron pipe on oil tank vent wrybosome Plumbing 3 01-13-2009 10:43 PM
Underground orangeburgh pipe leading to storm sewer is blocked somewhere flashme18 Plumbing 10 07-22-2008 12:48 AM
