How To Dislodge Frozen Drain Escutcheon - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-10-2012, 10:37 AM   #1
Rewards Points: 1,062
How to dislodge frozen drain escutcheon
People,
Have a bidet, and trying to remove the drain- I mean, unscrewing the upper portion (chrome finish escucheon, which sits in the bottom of bidet) from the female threaded steel (brass?) bottom part of drain assbly. Seems frozen tight. tried heat with propane torch, but doesnt budge.
What do you guys do in this situation?
Thanks.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 11-10-2012, 10:45 AM   #2
DIY staff
Rewards Points: 7,174
Picture might help---I never took a good look at that type of drain---
Old 11-10-2012, 11:41 AM   #3
Big thanks, Mike. Pictutre is coming soon..........
Old 11-10-2012, 11:52 AM   #4
Old 11-10-2012, 11:53 AM   #5
There it is, Mike. Oh, its technicaly called the "flange". Its not different than many other flanges. Its frozen.....
Old 11-10-2012, 01:08 PM   #6
DIY staff
If you are replacing it---saw a slice into it with a Dremel---then split it off the threads
noquacks (11-10-2012)
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
setting a shower drain Jackets Plumbing 16 05-10-2012 08:48 PM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
Frozen Garage Floor Drain Dragon General DIY Discussions 8 01-25-2009 06:07 AM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
