How Deep Should It Go? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-04-2013, 11:46 AM   #1
How Deep should it Go?
I am tying to screw a 3/4" threaded copper male nipple into a brass Kohler Thermal Expansion Valve.
I can thread it to the point where roughly 3 threads are still exposed until it gets extremely difficult to tighten. i have used the white teflon compound as thread sealant which does not harden.
I am wondering if it's good enough or if I have to ensure that all the female threads make contact with a male thread.
I
I
Thank
hotelinorbit is offline   Reply With Quote
Old 07-04-2013, 11:57 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 566
Thank
Welcome to DIY Chatroom
If you have doped the male threads (personally I dope & tape) you simply tighten until it's good and tight - about 7 threads should be buried in the female fitting. Sometimes a little less
The threads are a tapered pattern so eventually it will be tight. Call it good when that happens. Having left over threads exposed is normal
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (07-04-2013)
Old 07-04-2013, 12:07 PM   #3
Thanks so much. Makes me feel much better.
Happy 4th of July!!!!
The Following User Says Thank You to hotelinorbit For This Useful Post:
TheEplumber (07-04-2013)
deep counter tops ? Fix'n it Remodeling 9 04-25-2013 11:07 AM
Can I go from 6" to 8" deep sink? (picture) addfsd Plumbing 19 03-02-2013 09:38 PM
looking for 12" deep microwave for built-in look acerunner Appliances 9 05-18-2011 09:24 PM
How hard is your water? How deep is your well? brokenknee General DIY Discussions 10 05-05-2009 07:17 PM
New Deep Tub ~ Needed Raised Deck .. Faucet for Deep Deck? Hisgirl Plumbing 1 01-17-2009 11:00 AM
