Old 09-21-2009, 11:36 AM   #1
How to deal with greasy black deposit inside of drain pipes?
When unclogging old drains, I'm running into thick black greasy deposits in the pipes a lot. This stuff is really hard to clean off of everything, it is sort of like glue. I'm sure many of you have dealt with it.
Is something that can clean it off efficiently? Soap is useless. Maybe paint thinner or something like that?
Also does that 'Drain Care' bacteria and enzyme stuff work on the deposits? It's an interesting product but I doubt it can work miracles. I run the snake through the pipes a couple of times but I can't really make much of an impact on that thick greasy stuff on the walls.
darsunt is offline   Reply With Quote
Old 09-21-2009, 12:55 PM   #2
Orange Glo works pretty well and I use Gojo for my hands.
Rege
RegeSullivan is offline   Reply With Quote
Old 09-22-2009, 09:24 AM   #3
that is grease .I clean all my snakes with formula 44 ,then wash with hose no soap
metx is offline   Reply With Quote
Old 09-22-2009, 11:24 AM   #4
You get it on the walls?? thats not cool. you using an open drum? I use a closed drum and make sure not to have kinks in my cable. simple green works pretty good. sounds like those lines could use a jetter.
plumber Jim is offline   Reply With Quote
Old 09-23-2009, 08:16 AM   #5
Long-Time DIYer
Mike Swearingen's Avatar
Yes, DrainCare enzyme-based drain cleaner will work on that black stuff.
I begin the line flushing after DrainCare eating on it all night with a kettle of boiling water followed by hot water line only running until it's all flushed away. Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
reuse black pipes nikwah Plumbing 5 10-12-2008 10:38 PM
new ( to me ) house... cold inside, warm outside... what's the deal? MrLinux General Discussion 7 02-13-2008 09:33 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 10:36 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
