How To Cut Toilet Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-09-2012, 03:47 PM   #1
Rewards Points: 518
How to cut toilet drain?
I have a roughed in toilet drain stub(4" ABS I believe) that is sticking out of the ground about a foot with a cap on it. I need to cut it down to the proper height. What is the best way to get a clean cut on a pipe this wide?
n0c7 is offline   Reply With Quote
Old 05-09-2012, 08:01 PM   #2
DIY staff
Rewards Points: 7,174
Saws All with a hacksaw blade works well---Japanese pull saw is swell---what do you own?
n0c7 (05-10-2012)
Old 05-09-2012, 08:13 PM   #3
Rewards Points: 518
Rec saw, circular saw, dremel, couple of hand saws.
Old 05-09-2012, 10:55 PM   #4
You have to cut it below the floor. There is a tool that goes into a drill for doing this. It looks like a large drill bit with a tiny (about 2 inch)circle saw blade on the end. Look in the plumbing section at Home Depot where they keep the Ridgid plumbing tools. You cut from inside the pipe with it.
UFoPilot is offline   Reply With Quote
Old 05-09-2012, 11:47 PM   #5
Try an inside pipe cutter, http://www.homedepot.com/buy/plumbing-plumbing-tools/brasscraft-inside-pvc-pipe-cutter-123985.html.
Or this one. http://www.homedepot.ca/product/brasscraft-pvc-cable-saw/909086. I've always been curious how well this would work.
VIPlumber is offline   Reply With Quote
The Following 2 Users Say Thank You to VIPlumber For This Useful Post:
n0c7 (05-10-2012), plummen (05-11-2012)
Old 05-10-2012, 12:05 AM   #6
Originally Posted by VIPlumber View Post
Yep, that's it. It works great.
Old 05-10-2012, 10:45 AM   #7
Rewards Points: 518
I saw the second one in Scarface I think. Seemed to work well.
Old 05-10-2012, 08:10 PM   #8
Rewards Points: 630
yes they work well untill your keyless chuck drill loosen up and down the pipe it goes.
so i always stuff a rag down a little deeper in pipe so if it does fall out you can reach it
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
The Following 2 Users Say Thank You to jaydevries For This Useful Post:
dogris (05-11-2012), plummen (05-11-2012)
Upstairs Toilet Drain wab Plumbing 13 06-14-2011 12:15 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet bowl won't drain. Sikorsky Plumbing 5 12-31-2009 07:05 AM
shower drain vs tub drain--connected to toilet???? mandalala Plumbing 2 06-24-2009 03:00 PM
toilet drain line rbaggett Plumbing 2 11-28-2008 11:54 AM
