How To Cut Into Hot Water Line? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-09-2010, 03:22 PM   #1
Rewards Points: 77
How to cut into hot water line?
I am wanting to cut into the hot water line leaving my hot water tank in order to put in a temporary line to feed my washer. There is no shutoff valve from the tank to where i want to cut. What do i do?
bcbud3 is offline   Reply With Quote
Old 02-09-2010, 04:04 PM   #2
Can you not shut the whole house water off, while you perform this plumbing change? Open the faucets, and drain as much water out from the pipes as you can.
oberkc is offline   Reply With Quote
Old 02-09-2010, 05:54 PM   #3
Is there a shutoff on the line going into the tank on the cold water side??
If there is shut that off.
SULTINI is offline   Reply With Quote
Old 02-09-2010, 07:20 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Journeyman Plumber
Old 02-09-2010, 07:31 PM   #5
Rewards Points: 77
thanks
Old 02-10-2010, 07:14 AM   #6
Originally Posted by bcbud3 View Post
thanks
Your welcome be careful go slow it might take some time to DE pressurize it. Don't just cut in make sure you drain the hot water till no pressure.
Old 02-10-2010, 06:28 PM   #7
Rewards Points: 1,514
Turn off valve above water heater or turn off main water valve.
Turn off water heater heating (flip off breaker for electrics).
Open some hot faucets upstairs.
Drain about two gallons from the water heater drain valve (to make sure all the water in the pipes above you comes down.)
Now you should be able to work on the pipe without getting wet.
Turn the water back on and observe water flowing from a hot faucet before turning the water heater back on.
Old 02-11-2010, 10:07 AM   #8
General Contractor
You can remove the drain tube from the relief valve and install a 3/4" nipple with a reducer on it that can attach to your air compressor. Hold the lever on the relief valve open. Use the compressor to drain the tank then the the water lines by opening up the lines via the faucets. Make sure the breaker is off and the main shut off valve for the house is closed or if on city you can turn the valve off at the meter.
ARI001 is offline   Reply With Quote
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
water line joint leak dtzulu Plumbing 4 05-14-2009 09:18 PM
Water softener off the main line? scottyja Plumbing 1 02-03-2009 07:16 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
