Old 06-12-2007, 11:45 PM   #1
Question
How to cut a 20 year old soil pipe
Does anyone have any experience in cutting a 20 year old hub type soil pipe9 cast iron) to do a repair. This pipe is below grade in a house built in the early 1980's. I've been told to use a chain type cutter but it might crack the pipe? I cannot get down there with a grinder but I can with a sawzall but I don't know what bale to use? Thanks
wibass is offline   Reply With Quote
Old 06-13-2007, 12:24 AM   #2
That one Guy's Avatar
Score the the pipe with the cutter. Snug the chain down around the pipe and turn it back and forth. Snug alittle more then snap.
That one Guy is offline   Reply With Quote
Old 06-13-2007, 02:39 AM   #3
Carbide grit blade. Cut the pipe, not the fitting. If you cut into the fitting, it will take you all day and a lot of blades. 4" cast, I can cut it in about a minute or so. Chain cutter (aka snap cutter) works well too.
Tankless Man is offline   Reply With Quote
Old 06-21-2007, 06:10 PM   #4
Union HVAC Tech.
Lennox also make an 8" blade for cutting cast iron which lasts longer than the carbide ones.
bigMikeB is offline   Reply With Quote
Question regarding soil makeup (will my soil amendment idea work?) joeyboy Landscaping & Lawn Care 5 06-30-2007 11:24 PM
Use of coupling fitting on gas pipe Fred Plumbing 3 01-28-2007 07:13 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
