-   -   How to cut a 20 year old soil pipe (http://www.diychatroom.com/f7/how-cut-20-year-old-soil-pipe-9121/)
wibass 06-12-2007 10:45 PM
Does anyone have any experience in cutting a 20 year old hub type soil pipe9 cast iron) to do a repair. This pipe is below grade in a house built in the early 1980's. I've been told to use a chain type cutter but it might crack the pipe? I cannot get down there with a grinder but I can with a sawzall but I don't know what bale to use? Thanks
That one Guy 06-12-2007 11:24 PM
Score the the pipe with the cutter. Snug the chain down around the pipe and turn it back and forth. Snug alittle more then snap.
Tankless Man 06-13-2007 01:39 AM
Carbide grit blade. Cut the pipe, not the fitting. If you cut into the fitting, it will take you all day and a lot of blades. 4" cast, I can cut it in about a minute or so. Chain cutter (aka snap cutter) works well too.
bigMikeB 06-21-2007 05:10 PM
Lennox also make an 8" blade for cutting cast iron which lasts longer than the carbide ones.
