How Critical Are Perfectly Straight Cuts In Pvc? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-06-2012, 11:06 AM   #1
Rewards Points: 16
How critical are perfectly straight cuts in pvc?
doing a sprinkler system, and running a line for a hose bib.
I've cut everything by hand and the cuts are pretty straight, but I'd be lying if i said all, or even most, were perfect.
I know i know they should be perfect, but they are so very close.
Can any experienced plumber shed some light on this? thanks!
jfryjfry is offline   Reply With Quote
Old 10-06-2012, 11:26 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 436
In the real world, close is good enough. More important, IMO, is to deburr the pipe
Old 10-06-2012, 11:42 AM   #3
Rewards Points: 16
awesome peace of mind. thanks so much!
and yes, deburring the pipes. esp on the inside.
and to quantify the imperfection of my cuts, some of the earlier (read: worse) ones are at the most 1/8" off.
Old 10-06-2012, 12:02 PM   #4
Plumber
Rewards Points: 436
That's OK
Old 10-06-2012, 12:13 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
OMG....1/8" off?
Stop.....you must redo it all.......no more than .0001" from center.....otherwise, you might get a leak in about 200 years.
Ok....now that I've had my fun.....
Yea....your fine.......
As eplumber said....debur.....and make sure you give that fitting a good twist when you slip it on. This causes the cement to be evenly spread in the joint making for a better bond.
Old 10-06-2012, 12:40 PM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
IMO if you're using a ratcheting cutter, deburring the outside is even more important, because the burr will actually push the glue out of the fitting if you don't remove it.
If you're using a hacksaw or sawzall, just getting the rough chips off the edges is good enough.
Journeyman Plumber
Old 10-06-2012, 01:09 PM   #7
the Musigician
DangerMouse's Avatar
When I did mine, I used a plain old pipe cutter. (wheel type) and used the attached end to deburr the insides. The most important part is using the cleaner/primer first, then use enough glue to do the job well. The inspectors also don't mind seeing a bit too much purple, because they know you did it right that way.
DM
Old 10-06-2012, 01:56 PM   #8
Rewards Points: 16
Appreciate the help from you guys. experience is so valuable. Had wondered why SO impt to deburr outside and now I know!
I had read that the last 1/8" of the joints was interference and was the most impt part but I guess since it was on the Internet, it's worth what I paid for it.
Perfectly straight line Casey Flooring 13 04-05-2011 11:18 PM
Special saw for clean cuts in drywall / plaster jamiedolan Drywall & Plaster 7 02-02-2009 07:05 PM
Rigid Metal Straight Threads rjordan392 Electrical 2 06-24-2007 12:42 PM
Bad tile cuts krush Flooring 5 06-18-2007 10:15 AM
Walls That Aren't Straight Not Sure Building & Construction 4 12-27-2006 12:55 PM
