-   -   How critical are perfectly straight cuts in pvc? (http://www.diychatroom.com/f7/how-critical-perfectly-straight-cuts-pvc-159142/)
jfryjfry 10-06-2012 10:06 AM
doing a sprinkler system, and running a line for a hose bib.
I've cut everything by hand and the cuts are pretty straight, but I'd be lying if i said all, or even most, were perfect.
I know i know they should be perfect, but they are so very close.
Can any experienced plumber shed some light on this? thanks!
TheEplumber 10-06-2012 10:26 AM
199 Attachment(s)
In the real world, close is good enough. More important, IMO, is to deburr the pipe
jfryjfry 10-06-2012 10:42 AM
awesome peace of mind. thanks so much!
and yes, deburring the pipes. esp on the inside.
and to quantify the imperfection of my cuts, some of the earlier (read: worse) ones are at the most 1/8" off.
TheEplumber 10-06-2012 11:02 AM
199 Attachment(s)
That's OK
ddawg16 10-06-2012 11:13 AM
OMG....1/8" off?
Stop.....you must redo it all.......no more than .0001" from center.....otherwise, you might get a leak in about 200 years.
Ok....now that I've had my fun.....
Yea....your fine.......
As eplumber said....debur.....and make sure you give that fitting a good twist when you slip it on. This causes the cement to be evenly spread in the joint making for a better bond.
Alan 10-06-2012 11:40 AM
IMO if you're using a ratcheting cutter, deburring the outside is even more important, because the burr will actually push the glue out of the fitting if you don't remove it.
If you're using a hacksaw or sawzall, just getting the rough chips off the edges is good enough.
DangerMouse 10-06-2012 12:09 PM
When I did mine, I used a plain old pipe cutter. (wheel type) and used the attached end to deburr the insides. The most important part is using the cleaner/primer first, then use enough glue to do the job well. The inspectors also don't mind seeing a bit too much purple, because they know you did it right that way. :)
DM
jfryjfry 10-06-2012 12:56 PM
Appreciate the help from you guys. experience is so valuable. Had wondered why SO impt to deburr outside and now I know!
I had read that the last 1/8" of the joints was interference and was the most impt part but I guess since it was on the Internet, it's worth what I paid for it.
