How To Connect Valve To Transfer Switch When 9/16" Off! - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-17-2013, 06:50 PM   #1
How to connect Valve to Transfer Switch When 9/16" off!
They say a picture is worth a thousand words... Please open below and scroll to the second page. On the top right corner there is an "Example" picture.
http://www.moen.com/shared/docs/inst...s/ins1972a.pdf
That's what I am trying to install. As you can see, the 1/2 copper pipe coming out of the valve (bottom) and going into the transfer switch (top) are shown to be 9/16" off. Is there a copper fitting that can handle that?
I wish instructions were better!
KevinAndrews is offline   Reply With Quote
Old 05-17-2013, 06:56 PM   #2
DIY staff
Rewards Points: 7,174
Use a 45* and a street 45* that should move that pipe back the 9/16s you need---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
ben's plumbing (05-17-2013), DannyT (05-17-2013)
Old 05-17-2013, 07:08 PM   #3
Roofmaster
Rewards Points: 2,172
Zackly what I was going to say. GO, OH, Mike!
Old 05-17-2013, 08:04 PM   #4
DIY staff
He might not know what a street 45 is..........
Old 05-17-2013, 09:56 PM   #5
Thank you, guys. Fortunately, I learnt "street" term last night, when I posted another question. ;-)
There is almost 7 inches between the two valves.
So, the suggestion is to connect a 45 street elbow to the pipe, then connect a regular 45 elbow to that, then run a short pipe from there to the valve?
HD has 3 kinds of 45 valve. http://www.homedepot.com/webapp/cata...ry=Search+All-
I expect you are referring to #2 and #4 in above link?
Would using flexible copper pipe be an option?
http://www.homedepot.com/p/1-2-in-x-...L010/203654407
Old 05-17-2013, 10:15 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 556
You want a st 45 and a regular 45- items 2 & 3 in your link.
You pipe out of the valve- build the offset- then pipe into the next valve.
I don't recommend soft copper.
The Following User Says Thank You to TheEplumber For This Useful Post:
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 07:07 AM
power transfer switch with circuit breakers slyttle Electrical 5 11-27-2012 06:12 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Generator with 2 transfer switches? Isaac-1 Electrical 4 03-16-2009 07:45 PM
Furnace Transfer Switch... caseywa HVAC 16 02-18-2008 09:14 AM
