How To Connect Two Washer Machine Hoses? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2012, 10:55 PM   #1
How to connect two washer machine hoses?
Hello,
A plumber suggested me to buy 2 6' braided washing machine hoses and 1 hose coupling male x male to put washing machine hoses together. The hose coupling is the one below
http://www.lowes.com/pd_34198-104-A-...620&facetInfo=
But it is not clear to me how to connect the hoses with the splicer. So please kindly provide instructions in detail.
Thanks!
anoy is offline   Reply With Quote
Old 02-02-2012, 11:17 PM   #2
Rewards Points: 256
http://m.lowes.com/mt/www.lowes.com/...ductId=3134247
The product you need is a male hose to male hose coupler, which will look similar to the one in the link I shared. I have a suspission that the coupler you need doesn't exist, because nobody should ever need one.
If I were you, I would fix the situation causing your hose to bee to short (move the supply connections near the drain connections).
Or if you aren't going to plum it correctly, just get a short garden hose rather than splicing two washing machine hoses together.
michaelcherr is offline   Reply With Quote
Old 02-02-2012, 11:40 PM   #3
Can I ask why you need 12' of washing machine hose? Seems like the machine is a little too far from the water source.
VIPlumber is offline   Reply With Quote
The Following 3 Users Say Thank You to VIPlumber For This Useful Post:
ben's plumbing (02-02-2012), gregzoll (09-26-2013), plummen (02-02-2012)
Old 02-02-2012, 11:40 PM   #4
The one I bought was suggested by staff at Homedepot. What is the splicer for? I think your link looks like more useful for my purpose. Did you mean to have a longer garden hose instead for my steam dryer?
Thanks again!
Old 02-02-2012, 11:43 PM   #5
Indeed for a steam dryer, which is not adjacent to a washer.
Old 02-02-2012, 11:45 PM   #6
Rewards Points: 582
Thanks again!
the staff at home depot is wrong... move machine closer to plumbing or move plumbing closer to machine....
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 02-02-2012, 11:50 PM   #7
Certainly your suggestions were well taken. But due to the space limitation, perhaps a cost-effective way is to have a longer hose connecting plumbing to the dryer.
Old 02-03-2012, 12:08 AM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 452
Thanks again!
Don't trust anyone in an orange apron. Get the in the link that was suggested.
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (02-03-2012), gregzoll (09-26-2013)
Old 02-03-2012, 08:20 AM   #9
Rewards Points: 3,130
Aah, say it ain't so!
Old 02-03-2012, 08:58 AM   #10
Rewards Points: 256
If you need your hose to be 12' just buy a 12' hose.
http://www.pexsupply.com/Wal-Rich-27...ne-Hose-Bagged
Old 02-03-2012, 09:03 AM   #11
Rewards Points: 256
And to answer your question, the part that the orange apron idiot had you buy is for mending garden hoses
Imagine a hose with a hole. Cut out the bad section, pop that thing in and join with hose clamps. It will leak eventually, but for occasional outdoor use that doesn't tend to matter. For a semi-permanant indoor hookup, I've given two cheap solutions, as it seams plumbing it legit is not an option for you.
Old 09-26-2013, 09:01 PM   #12
Bill Kearney
Rewards Points: 1,174
So add plumbing to get it closer to the dryer. Seems smarter than putting your home at risk of severe water damage due to a failed hose.
wkearney99 is offline   Reply With Quote
Problem with washer machine. Need help dukect Appliances 4 02-11-2010 12:31 PM
Flood safe washing machine hoses ielliott Plumbing 4 12-25-2009 01:56 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 07:32 PM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 11:40 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
