How To Connect A Trap Primers For A Hot Water Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-25-2010, 12:06 AM   #1
Rewards Points: 29
How to connect a trap primers for a hot water tank
Just find a trap primer on top of my hot water heat, and connect to my garden horse, who knows the righ way to connect it for hot water tank? Thanks
A picture attached below
Ballastar is offline   Reply With Quote
Old 02-25-2010, 06:12 AM   #2
I have no idea to what you refer. If you want to drain or flush the tank, the drain is at the bottom side of the tank. Usually, the only fittings at the top are for cold inlet/hot outlet. The over temp/pressure valve is usually on the side towards the top. This is a safety valve, don't remove it.
Old 02-25-2010, 09:12 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Are you saying you have a trap primer near your water heater that's being fed by a garden hose?
OR
Do you have a garden hose running from the temperature pressure releif valve on the tank into a floor drain?
Make sure your terminoligy is correct before you proceed. Please take a picture.
Journeyman Plumber
Old 02-25-2010, 11:26 AM   #4
Rewards Points: 29
The trap primer is on the top of hot water tank, but it connect to garden hose, not connect to water heat cold water inlet, is it right?
Old 02-25-2010, 11:28 AM   #5
Rewards Points: 29
Hope this time picture is attached, the trap primer installed here is make sense?!
Old 02-25-2010, 12:38 PM   #6
Rewards Points: 1,494
The trap primer is not associated with and is not needed by the water heater or the garden hose spigot.
The trap primer needs to be put somewhere in the cold water line where the flow starts and stops every once in awhile but preferably not too frequently. It discharges a small amount of water into the floor drain to keep the trap from drying out.
You might want to observe it to see whether use of hot water triggers the release of water and how much water comes out. Using the garden hose should do this. Since there is no timer to periodically release water, the primer relies on changes in water pressure inside the pipe to do this. The process is unscientific; it is up to you to compute how much water the trap needs and then, if possible, calibrate the primer (most people don't bother). The only disadvantage to releasing water too often is increasing your water bill.
Is my Hot Water tank Going K.M.G Plumbing 15 09-02-2009 05:35 PM
Need help with smelly and black well water!! HABSFAN2006 Plumbing 20 04-27-2009 10:54 PM
Insane water pressure in shower!!! Sarah24 Plumbing 5 12-09-2008 05:27 AM
Solar hot water + tankless gp_wa Plumbing 3 08-27-2008 12:48 PM
Hot water tank leak Bill46 Plumbing 1 08-20-2008 09:34 PM
