How Connect Toilet Valve To Garden Hose? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-28-2014, 09:02 AM   #1
How connect Toilet Valve to Garden Hose?
Hi!
I'm looking for the shortest way to connect a 7/8" toilet valve straight to a Female Garden Hose for a project. Is there a single adapter that will make this connection and still keep the connection as short as possible?
A 7/8" Female IP x Female Garden Hose adapter would be perfect is such a thing exists. If not, how would I do this??
Thanks,
Dave
dlancep1 is offline   Reply With Quote
Old 03-28-2014, 09:28 AM   #2
Rewards Points: 256
Home depot has a pretty good selection of adapters it may take a couple fittings but it is still better than ordering something online to me.
JustinK is online now   Reply With Quote
Old 03-28-2014, 09:30 AM   #3
Owner
LateralConcepts's Avatar
Might find what you're looking for here - http://www.plumbingsupply.com/hoseadap.html
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 03-28-2014, 09:42 AM   #4
Rewards Points: 256
It maybe easier to connect a toilet supply line up first and then adapt from 3/8 or 1/2 to garden hose
The Following User Says Thank You to JustinK For This Useful Post:
SHR Plumber (03-28-2014)
Old 03-28-2014, 10:29 AM   #5
What he said
broox is offline   Reply With Quote
Old 03-28-2014, 11:25 AM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,074
Originally Posted by dlancep1 View Post
Hi!
Thanks,
Dave
Ayuh,.... There's fittin's that go from 3/4" pipe to hose, 'n 1/2" pipe to hose,...
Never heard of 7/8" pipe,...
Old 03-28-2014, 11:41 AM   #7
Rewards Points: 256
Just another example of manufactures making things more difficult to sell more product.
Old 03-28-2014, 12:07 PM   #8
Rewards Points: 20
No, no, no. Ballcocks (toilet fill valves) have always had their own thread type. No pipe is ever designed to screw on to the ballcock threads directly. All connections must be some sort of compression, i.e. rigid or flexible toilet supply line or pex adapter fitting. Just do what "JustinK" posted, come off the ballcock with a flexible toilet supply line. To make it easier use a 7/8 ballcock x 1/2" fip sized line. From the 1/2" fip you can screw in a 1/2" mip x female hose thread adapter. Any store that sells plumbing supplies should have the fittings you need for this simple hook-up.
SHR Plumber is offline   Reply With Quote
Old 03-28-2014, 12:12 PM   #9
Rewards Points: 256
Ya at one point the manufacture decided to make there own thread type. Even if it was 60 years ago
So what are you building Dave?
Garden hose with internal timer bluefoxicy Plumbing 10 09-10-2013 12:58 PM
Toilet water supply valve compression ring corroded - how to unscrew the nut now? Jenju Plumbing 29 02-19-2013 08:50 PM
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 07:07 AM
toilet fill valve? Roundeye Plumbing 11 07-26-2011 01:17 PM
Leaky Toilet Tank Valve Tuckahoe Sparkplug Plumbing 4 07-10-2010 06:21 AM
