How To Connect A Smaller PVC To A 2in Rubber Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-25-2009, 11:06 AM   #1
How to connect a smaller PVC to a 2in Rubber Drain?
I need a better way to connect the PVC pipe from the kitchen sink to the drain in the floor. Problem is that the PVC pipe is smaller than the rubber drain pipe in the ground. Can someone please give me some tips to remedy this? Thank you....Steph
I can email you the pic if needed. I can't get it to upload.
WRrealtor is offline   Reply With Quote
Old 05-25-2009, 02:36 PM   #2
PVC reducers come in all sizes
hayewe farm is offline   Reply With Quote
Old 05-25-2009, 03:59 PM   #3
will it work in reverse for my set up? I have one pipe from the sink drains that goes into another pipe and then into the rubber drain.
Old 05-25-2009, 04:54 PM   #4
There is a PVC nipple that you glue on the pipe at the end where it leaks, the other end is threaded and accepts the drain pipe with a compression ring and nut just like the one above the leak.
Old 05-26-2009, 07:41 AM   #5
Rewards Points: 150
get a 11/2" male trap adapter with a slip nut and washer
al's sewer is offline   Reply With Quote
Can I connect toilet drain to this drain pipe james739 Plumbing 11 04-24-2009 08:06 AM
Condensor drain Captflx HVAC 6 08-17-2008 11:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
