-   -   How to connect a smaller PVC to a 2in Rubber Drain? (http://www.diychatroom.com/f7/how-connect-smaller-pvc-2in-rubber-drain-45208/)
WRrealtor 05-25-2009 10:06 AM
1 Attachment(s)
I need a better way to connect the PVC pipe from the kitchen sink to the drain in the floor. Problem is that the PVC pipe is smaller than the rubber drain pipe in the ground. Can someone please give me some tips to remedy this? Thank you....Steph
I can email you the pic if needed. I can't get it to upload.
http://C:\Documents and Settings\Own...tchen sink.jpg
hayewe farm 05-25-2009 01:36 PM
PVC reducers come in all sizeshttp://thm-a04.yimg.com/image/917bc10994ebd574
WRrealtor 05-25-2009 02:59 PM
will it work in reverse for my set up? I have one pipe from the sink drains that goes into another pipe and then into the rubber drain. http://www.diychatroom.com/C:\Docume...hen sink 2.jpg
hayewe farm 05-25-2009 03:54 PM
There is a PVC nipple http://thm-a01.yimg.com/image/fabdb3d0c5e2505e that you glue on the pipe at the end where it leaks, the other end is threaded and accepts the drain pipe with a compression ring and nut just like the one above the leak.
al's sewer 05-26-2009 06:41 AM
get a 11/2" male trap adapter with a slip nut and washer
