How To Connect From Sink To Cut-off Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-10-2010, 04:06 PM   #1
how to connect from sink to cut-off pipe
I posted this as a reply to another thread, but I'm not sure if all see that so I'm posting a new thread.
I have a copper drain pipe stub for the sink sticking out of the wall, no threads. I'm replacing a bathroom vanity. I removed the vanity. I could not un-swett the p-trap, so I sawed it off with reciprocating saw, leaving the unthreaded 3.5 inch long stub. I believe it is copper.
I called a plumber who said the job is a quick job to get threads on the stub to which I could connect from my new sink/p trap. I think that if is so quick, I should be able to DIY to save the cost.
I talked to another DIY guy at work who described what looks like a 3-part compression adapter I could use. He said I could get it at Home Depot. I'd put one end over the stub end, then there's an inverted piece next, and finally the third part that screws into part one, compressing that part 2 and creating the seal. I've also seen of course the Fernco solution.
Another solution I've read about is the Fernco one.
Pipes will not be visible - they will be behind vanity doors.
I live in Massachusetts.
What solution is recommended? Are all these solutions code-compliant in Mass. ?
If Fernco is ok, how do I size it. When I look at Ferncos at my hardware store or Home Depot, how come the diameters don't match at all the real world measurements. The o.d. of my stub is 1 5/8 o.d.. The Ferncos I find for say 1 1/2 inch are over 2 inches in diameter when I measure them. What's up with that? And how do I size the Fernco to fit a 1 5/8 inch o.d. stub?
Thanks very much.
jbcampo is offline   Reply With Quote
Old 11-10-2010, 04:17 PM   #2
you may need to go to a plumbing supply house to find the fernco you need, the fernco you explain sounds like pvc to pvc (pvc has thicker walls, so larger O.D.) look for 1 1/2" copper x 1 1/2" pvc
I dont know the code where you live, you can call the city and ask a plumbing inspector
Ltnicks is offline   Reply With Quote
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
How to fix bathroom sink drain pipe ? cprao Plumbing 9 02-27-2010 08:15 PM
Can I connect toilet drain to this drain pipe james739 Plumbing 11 04-24-2009 07:06 AM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
reducing pipe size for sink drain bluebee1314 Plumbing 5 12-02-2007 12:53 PM
