How To Connect Shut Of Valves With Propex - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-04-2012, 04:58 PM   #1
Rewards Points: 87
how to connect shut of valves with propex
I am connecting my hot and cold 1/2" ProPex stub outs to my master bathroom sink.
Should I connect brass adapters like this to each line first and then screw my shut offs onto those or just use compression shutoffs directly to the propex?
I currently have some shark bite like slip on shut offs I got from Ace but they dont feel solid at all.
hellonoko is offline   Reply With Quote
Old 10-04-2012, 05:28 PM   #2
Rewards Points: 13,300
If it's a copper stub out then use a compression shut off.
Old 10-04-2012, 05:35 PM   #3
Rewards Points: 87
@joecaption - It's ProPex stub out all the way.
Because of how it is set up a copper stub wouldn't really do anything and would look even messier.
Old 10-04-2012, 05:39 PM   #4
If your saying you just stuck the Pex out of the sheetrock then it's done wrong.
Should have been one of the fittings that looks like this. There's several others avalible that do the same thing.
http://www.pexsupply.com/Viega-44227...-Elbow-w-Plate
Old 10-04-2012, 06:12 PM   #5
Rewards Points: 87
@joecaption - No its not sticking out of the sheet rock, there is no sheet rock the wall is brick.
Because I am remodeling and having all the plumbing in the lower level re-done the pex sticks straight up through the floor and into the lav cabinet.
It is done like this so that when / if I or someone puts in a furred out wall with insulation in it against the brick the pex can go inside that and then stub out properly. But for now it is just vertical stub outs.
Right now I just need to get the fixtures functional and solid.
On a side note why are the stub outs switched to copper like that? My plumber switched some of my stub outs on the upper level to come out of the floor with just pex. Toilets. Kitchen sink and so on.
Old 10-04-2012, 06:40 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 452
stops are available with propex ends. Or you can use your adapters- screw them onto the stops first, easier that way.
Old 10-04-2012, 06:44 PM   #7
Plumber
Rewards Points: 452
IMO- it's a matter of plumbers choice or perhaps he ran out of copper stubs or his helper did it. I know of no code that does not allow pex to be stubbed out at the wall or through the floor.
Old 10-04-2012, 07:16 PM   #8
Rewards Points: 87
@TheEplumber - my thinking with putting on brass adapters is that those shut off valves always get a leak / the handle breaks / they get stuck or something. And if you have the valve right on the pex you are going to have to cut off a section of pex to put a new one on.
I think with the upper level stub outs, my house is... less than pretty. Lot of ugly carpet and so on and he didn't think it was worth the time or cost since looks dont matter. As long as it's not a code or functionality issue I don't care really.
Old 10-04-2012, 08:22 PM   #9
Plumber
Rewards Points: 452
As for code- it doesn't matter in my area. I can't say for yours.
Good thinking on the stops- easy to change with the adapters
Old 10-04-2012, 08:32 PM   #10
Rewards Points: 720
@TheEplumber - those shut off valves always get a leak / the handle breaks / they get stuck or something.
A common mistake for DIY ers and some Pros is to operate the valve with too much force. When we feel it touch the seat when closing - STOP with a feather lite touch. When opening and we feel it touch the back seat STOP with the same feather lite touch.
Also I've found that if a new valve is dis assembled and plumber's grease applied to the threads and packing they will operate well nearly for ever, especially if they are exercised a few times a year. This is especially true with water that has a few undesirable minerals like calcium aka hard water.
Old 10-04-2012, 08:33 PM   #11
Doing it myself
Alan's Avatar
Rewards Points: 2,086
How is that wrong?
Journeyman Plumber
Water hammer after replacing shut-off valves? gspck Plumbing 8 11-24-2010 09:55 PM
"PEX" manifold valves Thurman Plumbing 3 10-30-2010 11:37 PM
Help? Replacing water shut off valves frozenmama Plumbing 4 09-28-2010 07:17 PM
No main power shut off vab53 Electrical 26 06-12-2010 03:51 AM
shut off valves on cast iron radiators bdw2677 Plumbing 2 10-21-2008 08:07 PM
