How To Connect Several Large Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-27-2012, 05:08 AM   #1
How to connect several large pipes
I have a specialty application where I need to connect several 9 inch very long pipes to each other. These pipes are bundled together so welding is out of the question as the innermost pipes will be impossible to reach adequately. The only thing I can come up with are things like snap-on push-fit connectors (good luck finding them in 9 inch diameters) or to have the pipe ends threaded and then use something along the line of a hexagonal threaded coupling (also good luck in reaching the inner pipes of the bundle). These pipes are long and heavy so they're going to be difficult to move around without a lot of help. I'm stymied so any assistance would be profoundly appreciated. Thanks in advance.
brid is offline   Reply With Quote
Old 09-27-2012, 06:46 AM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
What kind of pipes/what are they used for/picture?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 09-27-2012, 06:48 AM   #3
a photo and a drawing of what you are trying to accomplish would help greatly. what are these for?
Old 09-27-2012, 08:52 AM   #4
It's for an industrial chemical usage where each pipe has to carry a different chemical through a very long run. I have no photo as the project is in the planning stages. There are four pipes in the middle and 10 pipes around the perimeter of a 40" diameter. Imagine holding a stack of spaghetti in your hands when you're about to drop them in boiling water. Let me know if I can describe them further.
Old 09-27-2012, 10:03 AM   #5
how was it designed to be put together? no drawings or plans? if there is ever any trouble with the ones on the inside you would have to take a lot of pipes out to fix the bad one.
The Following User Says Thank You to DannyT For This Useful Post:
plummen (09-27-2012)
Old 09-27-2012, 10:50 AM   #6
This is what I've just drawn up from what I've been told by the company that needs this. Unfortunately they don't want to go to planning stage until they know that the 40 foot long sections can actually be connected properly. Think of the 40 inch outer sheath as a big pipeline and the individual 9 inch inner pipes as smaller pipelines running inside the big one. It's set up so that the inner pipes can be accessed by cutting an access panel through the outer sheath to get at them, and then welding the outer sheath back closed again. I appreciate your help!
Old 09-27-2012, 10:53 AM   #7
plummen's Avatar
Id say your beyond the level of a diy project,Id suggest talking to an engineer and getting an idea of what it is youre trying to accomplish material wise atleast before somebody gets hurt
Old 09-27-2012, 11:30 AM   #8
I had a meeting with an engineer yesterday and he had less of a clue than I do! He's going to be zero help unfortunately.
Old 09-27-2012, 05:25 PM   #9
Rewards Points: 1,216
This is not the proper venue for the job you are specifying. This is mostly house hold stuff not industrial piping.
You don't have the material the pipes are, no pressure requirements, no flow requirements, what is flowing through the pipes, what environment is it, allowance for expansion and contraction, weight of the entire structure for the main supports, vibration springs?, sorry you need an Industrial piping Engineer.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 09-27-2012, 05:57 PM   #10
Well, certainly not the bozo I talked to. I'll dig out another engineer somewhere... hopefully one that didn't get his P.Eng. off the side of a box of Frosted Flakes.
Old 09-27-2012, 06:34 PM   #11
biggles's Avatar
1000 'run of chemical supply lines is going to have to be welded and certified with x-rays somebody is going to get hung if the connections leak..
The Following User Says Thank You to biggles For This Useful Post:
allthumbsdiy (09-28-2012)
Old 09-27-2012, 06:51 PM   #12
Rewards Points: 582
yep agree this is not a diy project in no way shape or form...sorry ...
Old 09-27-2012, 07:09 PM   #13
Plumber
TheEplumber's Avatar
Rewards Points: 834
Are those pipes leading to a nuclear cooling tower?
Old 09-27-2012, 07:11 PM   #14
Rewards Points: 582
are we on candid camera.....:laughing :
Old 09-27-2012, 10:38 PM   #15
Yeah, it's kind of a DIY Manhattan Project. You'd be surprised how many bakers in the Ukraine make yellowcake.
tree roots and orangeburg pipes xerxes2001 Plumbing 3 04-07-2012 08:26 PM
Possible small gas leak in black iron pipes WillK Plumbing 4 01-17-2012 11:07 PM
Insulating hot water heating pipes Rav HVAC 7 12-07-2011 12:58 PM
Extra high vent pipes? fw2007 Plumbing 6 07-11-2008 08:07 AM
replacing rectangular duct with 6" pipes peso HVAC 4 06-05-2008 08:43 PM
