How To Connect Nylon Water Filter Fitting To 1/4" Copper - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-22-2013, 10:01 PM   #1
jkk
Rewards Points: 233
How to connect nylon water filter fitting to 1/4" copper
My house has a 1/4" copper line with nut & ferrule connecting it to a nylon fitting for the inline water filter. The nylon fitting is threaded. Is tape needed for this nylon to brass connection? Is the brass ferrule also used?
jkk is offline   Reply With Quote
Old 10-22-2013, 10:06 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Picture?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 10-22-2013, 10:08 PM   #3
Rewards Points: 582
picture of what you got is needed to help you ..as far as nylon into brass..i would use teflon tape on the threaded adapter...ben sr
Old 10-22-2013, 10:26 PM   #4
jkk
Rewards Points: 233
How to connect nylon water filter fitting to 1/4" copper-fitting.jpg
Old 10-22-2013, 10:36 PM   #5
plummen's Avatar
Ive never seen a plastic fitting quite like that one before,Id say there should be a ferrule under the brass nut.
Be carefull putting too much teflon tape on there or you could crack/split the fitting.
Need Help Figuring Out Proper Filtration Setup HiccaBurp Plumbing 8 05-08-2012 02:28 PM
RO water filter systems jamiedolan Plumbing 10 04-27-2009 11:21 PM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 11:36 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
