How To Connect Non-threaded 1/2 Inch CPVC To A Compression Shut-off Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-11-2006, 07:37 PM   #1
Question
How to connect non-threaded 1/2 inch CPVC to a compression shut-off valve
Hi Experts,
I have this dilemma. I have 1/2 inch cpvc. I need to connect a metal compression shut-off valve to this cpvc. Any idea of how I should proceed? I am new to this, please explain in detail.
Thank you,
Andy
andy is offline   Reply With Quote
Old 12-11-2006, 10:26 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Just like compressing it on copper, slip it on and tighten it up.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 12-12-2006, 12:37 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
Use a backup wrench on the valve to hold it steady, and tighten the nut tightly.
The compression ring actually seals it, not the threads, so if it slightly leaks after you tighten it, smear a litle clear silicone caulk on the brass ring ferrule instead of the threads.
That "clear silicone caulk" always chokes my ole buddy Ron. LOL (He's a pro, I'm not...but it works for me.)
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 12-12-2006, 09:35 AM   #4
Question
ok, but...metal compression ring
Ok...then I have this question. I read somewhere that you are not supposed to use a metal compression ring on a cpvc pipe (maybe because it can crack the pipe when tightening). Is that true? What I am talking about is if I use a metal compression ring from the valve fitting on cpvc pipe...is that allowed/going to work? Should I maybe be using a plastic compression ring instead? Please let me know.
Thank you
Old 12-12-2006, 07:10 PM   #5
Journeyman Plumber
You can use the metal compression ring on cpvc, take hand tight then 1/2 turn more tight, if you get a leak, tighten little at a time.
Old 12-12-2006, 09:56 PM   #6
Long-Time DIYer
(Slowly I creep...inch by inch...CAULK!)
LOL
Old 12-12-2006, 10:02 PM   #7
Journeyman Plumber
I like to apply a thin coat of pipe dope on the points that create the seal.
Someday I'll come across a job where there was caulk used and I'll ask where did they learn that, I bet they will say Mike on DIYChatroom told them that.
dripping from water shut off valve underneath the toilet maitri Plumbing 4 12-10-2006 04:58 PM
compression valve farrington135 Plumbing 6 04-24-2006 02:38 PM
