How To Connect Condensate Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-12-2010, 02:35 PM   #1
How to connect condensate pump
Hi,
I am new to this forum, but not new to rennovations. I am having a high-efficiency furnace installed and require a condensate pump. I want to connect the drain line to an existing 1-1/2' ABS drain. I am trying to avoid using any metal fittings due to the acid content in the condensate. I can't seem to find any plastic fittings to connect to a 3/8' plastic pipe. (They are brass).
I notice that the Beckett pump also has male threads. Does anyone know what size of female thread it takes? I am thinking of connecting the pump into 1/2" plastic pipe then I can use all plastic fittings into the 1-1/2 ABS.
DCJH is offline   Reply With Quote
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Condensate pump install question kboorman HVAC 6 07-06-2012 07:54 PM
Condensate Pump confusion GlennAndrew HVAC 9 01-01-2010 05:25 PM
New Drain for HVAC Condensate Pump LoveMyHome Plumbing 6 12-05-2009 06:59 AM
Good furnace condensate pump? Tommy2 HVAC 11 12-12-2008 04:31 PM
