How To Connect 1/4" Copper To 3/4" For Humidifier - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-09-2012, 01:18 PM   #1
Rewards Points: 640
how to connect 1/4" copper to 3/4" for humidifier
What is the best way to go from a 3/4" water line to 1/4" soft copper to connect a furnace humidifier?
I was going to T the 3/4" cold line then put a copper stub and some type of shutoff valve (not sure what is best for this situation) then I guess a 1/4" line compression fit into that somehow?
Suggestions?
BlueBSH is offline   Reply With Quote
Old 02-09-2012, 01:30 PM   #2
They make a 5/8 compression(1/2 copper outside diameter) to 1/4" compression valve. do not use a saddle valve
broox is offline   Reply With Quote
Old 02-09-2012, 01:35 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Alright ,theres really nothing wrong with a properly installed piercing valve.
It suffers from most of the same issues as most smaller valves.
1-It needs to be turned on/off once in a while to keep it from getting stuck and clogging up.
2-when they do leak its normally caused by the packing nut under the handle getting seized to the stem from non use.
So when you turn one on or off that hasnt been used in a long time the packing nut ends up loosening when you open the valve,you can just snug up the packing nut while holding the handle most of the time.
The other common option is to cut a 3/4x3/4x1/2 tee in there and sweat a threaded bung fitting into the 1/2" side and thread a valve into it.
Either way you should open/close the valve a couple times a year to keep it from seizing up
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
how do i connect a bent copper pipe...... curlybird Plumbing 15 10-07-2011 12:54 PM
Do I need a ground rod to replace copper water pipe mfkcbk Electrical 10 11-11-2010 04:03 PM
How to Rewire aluminum to copper wall outlet. deepseathomas Electrical 1 10-20-2010 02:11 PM
Connect 2" pvc drain to 2" copper pipe - no subfloor access missfixer General DIY Discussions 3 09-05-2009 05:44 PM
Debate - Pex vs Copper sandy2982 Plumbing 13 04-10-2008 10:47 PM
