How To Clean Outside Sump? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2011, 01:17 PM   #1
Rewards Points: 640
how to clean outside sump?
My house has dual sumps / pumps one is inside in the basment floor the other is outside and goes into the ground about 13 ft... I can easily clean out the sump in the basement one as it is a whole 2 ft deep... but how in the world would I clean the one outside? the whole well for the sump is that big black corrogated pipe until the sump... water drains into the sump from perforations in the black corrogated pipe so dirt does get in also... the bottom looks pretty dirty... any ideas?
BlueBSH is offline   Reply With Quote
Old 01-27-2011, 04:17 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,618
Ayuh,... At 13' Deep, I wouldn't worry about a couple of inches lost to sediments....
Bondo is online now   Reply With Quote
Old 01-27-2011, 04:19 PM   #3
Rewards Points: 640
even when its clogging the pump? technically its at the same level as the pump in the basement, but of course the basement is below ground so 10ft of dirt ontop of what the basement floor would be at is in the way
Old 01-27-2011, 04:24 PM   #4
WDR
sump
I do not know if it would have enough suction but you could try a wet/dry vac with a length of pipe duct taped to the hose. If the pump is above the bottom not sitting in the sediment I would agree with Bondo in that cleaning is probably not necessary.
WDR is offline   Reply With Quote
Old 01-27-2011, 04:53 PM   #5
Bondo's Avatar
Ayuh,... You never said it is/was... Is it,..??
sump pit/pump questions aliasoink Building & Construction 8 03-02-2010 11:41 PM
Basement sump pumps, 1 runs more than other cjdock Building & Construction 3 11-02-2009 06:28 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Sump Pump Design handy man88 Plumbing 2 10-04-2008 09:48 PM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 11:59 AM
