Old 04-01-2008, 05:59 AM   #16
Send a message via AIM to Marlin
How to change the shower valve?
Originally Posted by amdspitfire View Post
You got it, exactly what I did.
I put a screw through the drywall behind the fixture and found out its coming out right behind the dining area. Great access from behind. Should I cut open the drywall, from behind ?
It's up to you. The valve can be changed from either side, open whichever wall is going to be easiest for you to repair afterwards. Usually it's the sheetrock wall to the back.
Marlin is offline   Reply With Quote
Old 04-06-2008, 03:57 PM   #17
After 4-5 days of no water, the new valve is finnaly in and not leaking. Leaked the first time because it was just super hard to get the torch up in there with out burning the house. The new Delta design is superior, what a huge difference.
amdspitfire is offline   Reply With Quote
Old 04-06-2008, 10:05 PM   #18
Glad to hear it. Congrats.
plumber Jim is offline   Reply With Quote
Pressure Balance Shower Valve Hammer glenn60 Plumbing 7 06-17-2009 09:30 PM
Question about shower valve? Rick Bruner Plumbing 3 03-23-2008 11:09 PM
Misbehaving shower mixer valve ranagnos Plumbing 6 03-03-2008 08:24 PM
shower valve doesn't "mix" moneymgmt Plumbing 9 01-23-2008 10:45 AM
aging symmons temptrol shower valve v240969 Plumbing 1 01-01-2008 06:24 PM
