How Are Cast Iron Drains? Do You Have To Plunger Them Often? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-25-2008, 08:52 PM   #1
Rewards Points: 150
How are cast iron drains? Do you have to plunger them often?
My home has cast iron drains. I redid my entire supply including the meter to the house. My supply works great. I have never had cast iron drains but my home has them. I haven't used the toilet yet since I am still restoring the house. How are cast iron drains? Do they last? Do you have to use a plunger more often since they aren't smooth inside like PVC? Any info would be appreciated.
twilightcall is offline   Reply With Quote
Old 08-25-2008, 08:57 PM   #2
Send a message via AIM to Marlin
In my opinion cast iron is still the best material going. It's strong, lasts a long time, and is quieter then PVC. Galvanized on the other hand sucks. If you have galvanized you will probably have slow drains on everything but your toilet which doesn't use galvanized.
Marlin is offline   Reply With Quote
Old 08-25-2008, 11:12 PM   #3
Registered User
Termite's Avatar
I've got a 1959 house with all cast iron stacks. It works great.
I regularly inspect high-end mansion-type homes, and cast iron is what those folks are installing. Especially in floors and walls.
Just keep them clean and running good and they'll last forever.
Old 08-28-2008, 08:17 AM   #4
Florida Cracker
From my experience, the life span of cast iron pipes (in Florida) is about 80 years. I have a property built in 1925, and I had to replace a section of the cast iron vent stack due a 4" x4" completely failing.
Also, a camera snake shows that the cast iron drain pipe under the house is cracking and will eventually collapse.
Other properties in my area of a similar age have the same issues.
Jack A. Trades is offline   Reply With Quote
Old 08-29-2008, 01:07 AM   #5
Rewards Points: 562
here is another tidbit of info,,,there was HEAVY cast iron,,,and LIGHT cast iron drain pipes,,,depends on which you have,,,heavier is better generally,,specially when you change it out to plastic and SELL the cast for scrap iron!!(smile) Any of it works great,till it dont work No more!!
4just1don is offline   Reply With Quote
Cast iron vs galvanized steel. duffers Plumbing 10 08-04-2009 11:35 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 11:07 AM
smoothening cut cast iron pipe before mounting fernco coupling amakarevic Plumbing 6 11-15-2007 06:39 PM
Help with Cast Iron Material Tester Plumbing 2 10-25-2007 11:58 AM
Current trends: Cast Iron or Stainless Steel sink? Fat b Remodeling 4 05-04-2007 08:09 PM
