How To Cap ABS Vent Pipe Over Roof? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-22-2010, 04:21 PM   #1
how to cap ABS vent pipe over roof?
I have a silly question. I have 2" ABS DWV vent pipes penetrating the roof. My roofer will waterproof everything. But I don't know how to properly terminate the pipe over the roof. Put a metal cap on it?
Thanks for any suggestion.
pttcc is offline   Reply With Quote
Old 08-22-2010, 04:35 PM   #2
You don't have to do anything but install flashing. The vent pipes connect to the drain system (obviously) so any water that goes in just goes to the sewer. The hardware stores around me carry mushroom caps if you're worried about it, or you can get screened caps at supply houses to keep animals/insect nests out of the vents
the_man is offline   Reply With Quote
Old 08-22-2010, 04:55 PM   #3
Rewards Points: 472
Leve it a lone . Don't put a cap on it . It need's to vent. It is hooked up to the septic tank or the sewer. Any way it need's the air intake to drain .In all the yrs i have never had any one have problum's Their is a led piece that goes over the roof and than folded over the pvc pipe. that is all that need to be
del schisler is online now   Reply With Quote
The Following User Says Thank You to del schisler For This Useful Post:
Michajr (03-19-2013)
Old 08-23-2010, 11:14 PM   #4
Sorry, I wanted to say 'sleeve' or 'boot', not 'cap'.
How many feet should I leave the ABS vent pipe above roof?
Thanks!
Old 08-23-2010, 11:27 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 566
Thanks!
Minimum 6", I usually extend 12" above the roof. Stay away from side walls, windows, and fresh air intakes
Tags
vent pipes
Stove pipe through roof overhang IDIY Roofing/Siding 2 08-12-2010 11:55 AM
Best roof cap for range hood vent bsperr HVAC 0 08-05-2010 02:33 PM
Correct Way to Flash a Vent Pipe With Metal Roof? jonathan03 Roofing/Siding 4 06-22-2010 03:57 PM
Vent pipe cover? Ultrarunner2017 Plumbing 2 04-16-2010 06:43 AM
Water leaking from vent pipe die_of_ennui Plumbing 3 03-25-2010 08:11 AM
