How Can You Let Your Inline-connections Cure Before Pressurizing? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-03-2010, 01:26 PM   #1
Military Mom of 4
Snav's Avatar
How can you let your inline-connections cure before pressurizing?
So I'm stumped by this.
I'm connecting the last bit of my inline for my faucets and all in the new bathroom. This time I'm using CPVC (pipe and fittings) instead of sharkbites/Pex.
So - I've done a lot of drain pipe without any problems but this is the first time I've ever used cement for a pressurized line. How long do I have to keep the inline void of pressure after I install the new fittings?
If I wait until tomorrow morning I can connect things via T into the old line - and that would give me maybe 8 or 9 hours. Is that long enough? Or should I plan for a lengthier time?
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 05-03-2010, 01:28 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
15 minutes is fine.
Coastal South Carolina
Old 05-03-2010, 01:35 PM   #3
Military Mom of 4
Snav's Avatar
Oh really - well then I'm bothered over nothing. By the time I get it all pieced together several hours would have gone by - and there will be nothing to worry about.
Easiest way to ground inline surge protectors? wmblalock Electrical 2 03-06-2010 10:07 AM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 10:36 AM
epoxy coat and resurfacing concrete cure time questions ?? waltereo Flooring 3 10-04-2008 11:43 AM
Wago terminals for residential line-voltage connections BigJimmy Electrical 3 05-22-2008 01:27 PM
MVP4 cure time... kemerick Flooring 1 12-15-2007 12:50 PM
