Old 05-17-2010, 10:46 PM   #1
Just call me Andrew
How can I tell if I have a leak?
I needed to replace an old toilet valve. It was connected to a 1/2" nipple coming out of the floor. The nipple came off as I unscrewed the valve. So I put a new valve at one end of the nipple, then screwed the nipple (with the valve attached) into the female threaded connection in the floor.
I can't see the connection I made in the floor, it is about 2" below the subfloor. I have connected pipe before, and I have no reason to believe it is leaking, but I can't see it to be sure, so it's bothering me. I gave it 4-5 wraps of monster teflon tape (the blue stuff) and tightened it pretty well, the same as I normally do. Any good way to find out, aside from a water spot in the (brand new) bathroom below?
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 05-18-2010, 07:07 AM   #2
A water spot is certainly a dead give away, but one way to check is look at the water meter with everything turned off. There is a little red dial in the face that shows small amounts of flow, if that is dead still, chances are good no leak. Check it for movement over say, 1-2 hours.
Old 05-18-2010, 07:46 AM   #3
Just call me Andrew
Great idea. It's been about 10 hours, and no water spot, so I think I'm good. I will check the meter though in a few hours, Thanks.
Andrew
Freon Leak captainron19 HVAC 3 04-16-2010 05:30 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 02:26 PM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 07:30 AM
Leak in incoming supply line under slab playstationdork Plumbing 13 08-05-2008 09:18 AM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 02:18 PM
