How Can I Run My Plumbing? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-05-2010, 08:28 PM   #1
Rewards Points: 77
How can i run my plumbing?
I am wanting to reno my laundry. I plan on insulating the concrete wall and building out a 2x4 frame for it. I am unsure how i can run my plumbing along this exterior wall. The exterior wall is 2x4 with panelling over top sitting on 8" concrete. I want the plumbing to be hidden. Help please?
bcbud3 is offline   Reply With Quote
Old 02-05-2010, 10:19 PM   #2
In Canada, the plumbing has to be on the warm side of the insulation. That's why it was run on the surface!
If you want to hide it, you could build a false wall in front of it!
Old 02-05-2010, 11:28 PM   #3
How to finish wall
You would need to cut and cap the plumbing, build the wall, then re-run the plumbing through the wall.
Hope this helps.
Occam's Razor - The simplest answer is probably the correct one.
JCAHILL4 is offline   Reply With Quote
Old 02-05-2010, 11:45 PM   #4
Hope this helps.
Why would this be necessary!
Old 02-06-2010, 01:36 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Because it will take too long to cut the plumbing out, build the wall, and redo the plumbing. You would probably have to have your water off for a couple days.
You could reroute your waterlines up into the top corner of the room, and soffit them in.
Otherwise :
1 : turn off water. Cut plumbing out to where it won't be in the way
2 : cap lines, turn on water to make sure caps don't leak
3 : build wall
4 : drill holes and run waterlines through wall
5 : turn off water and make final connection
6 : turn on water and check for leaks
7 : Finish wall, and connect plumbing as needed outside of wall.
Journeyman Plumber
Old 02-06-2010, 10:56 AM   #6
Otherwise :
3 : build wall
Sorry, I should have been more explicate!
Is there a code requirement that says that the pipes should run through the studs?
Is there a problem leaving them where they are? They haven't fallen down, as yet, so its unlikely that they would after a false wall is placed in front of them?
Old 02-06-2010, 11:39 AM   #7
Rewards Points: 77
I will be redoing all the plumbing anyways. Currently the washer and sink are about 15' away from the main drain/vent pipe. I want to move them closer. I will be reinsulating the wall as well. I think i might add to the 2x4 wall with some 2x2, reinsulate but leave the section where there will be pipe running down the wall only insulated to the 2x4.
Old 02-06-2010, 12:29 PM   #8
Doing it myself
Alan's Avatar
There isn't a requirement to run them through studs, but there is one that says it has to be supported every-so-often depending on type of piping and size..
IMHO it would be faster to drill holes after the wall is up rather than notching each stud as you go along. Besides, If you're remodeling something, I would probably always vote for replacing waterlines before you cover them up. No sense in covering up old lines that could possibly leak soon, but-who-knows?
Journeyman Plumber
Old 02-07-2010, 08:49 PM   #9
why don 't you just stub them out and then when you put your new wall up you won't have to cut holes and re-do you plumbing then? you'll have capped stub-outs ready to build off of.
frisco kid is offline   Reply With Quote
Old 02-07-2010, 09:09 PM   #10
Rewards Points: 77
i don't think i was clear enough. I am not planning on running my new 2x4 wall right up to the ceiling. Only high enough to cover the concrete. If iwas to run it up to the ceiling, i would haveapprox 6-7" of dead space between the new wall and existing exterior wall. I was thinking of furring out the exterior wall 2x4 with 2x2 but they are expensive!!
Old 02-07-2010, 10:29 PM   #11
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
you guys are making my head hurt!
plummen is offline   Reply With Quote
How to find plumbing distributors for plumbing invention? Timster Plumbing 14 03-14-2014 09:55 AM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 12:14 PM
