How Can I Get This Kitchen Faucet Off? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-05-2014, 12:03 PM   #1
Rewards Points: 20
How can I get this kitchen faucet off?
I purchased this faucet: http://www.homedepot.com/p/KOHLER-Cr...0-VS/203012966 and it seems like an easy enough installation. The bottom of the faucet looks like this:
Seems like all I have to do is screw something in and it will attach the sink to my counter top.
My old faucet:
Doesn't seem like it has the same mechanics. This is what I see under my kitchen counter top:
How do I get that off? I've tried twisting it as if the shaft is threaded but I don't think it was loosening at all.
zakiaziz is offline   Reply With Quote
Old 11-05-2014, 01:30 PM   #2
Rewards Points: 2,706
There is a big nut directly under your brass plate below the faucet. Hit it with some pb blaster let it soak and use a basin cock wrench.
Old 11-05-2014, 02:16 PM   #3
joed's Avatar
Rewards Points: 4,776
You need a basin wrench to loosen the nut below the brass piece.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 11-05-2014, 04:00 PM   #4
Rewards Points: 40
Knock that brass plate loose. It's not screwed on. Then remove the nut underneath. I'm no plumber but that's what I've seen.
Zorfox is online now   Reply With Quote
Old 11-05-2014, 04:29 PM   #5
Rewards Points: 20
Uhh, am i understanding this correctly?
Old 11-05-2014, 05:45 PM   #6
Rewards Points: 942
some of moen and kohler single faucets come with a wrench in box to remove that nut...basin wrench is going to be tough....
Old 11-05-2014, 07:50 PM   #7
If your not saving the faucet use a saws all and cut if off from the top.
Old 11-05-2014, 07:54 PM   #8
Rewards Points: 20
I'm not sure if the image I posted above is showing properly for everyone. This is a repost of the image:
Old 11-05-2014, 08:32 PM   #9
Plumber/Contractor
TheEplumber's Avatar
Rewards Points: 3,308
Is there a nut at the blue text? If so, that is holding the faucet in place. Remove it and the plate will come off too.
The threaded pipe- green text will not come off if you try to loosen it.
The Following 4 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (11-05-2014), Javiles (11-06-2014), r0ckstarr (11-05-2014), zakiaziz (11-05-2014)
Old 11-05-2014, 08:52 PM   #10
joed's Avatar
If you loosen the blue nut then I think the yellow clip will pop/slide out and the faucet will pull up.
The Following User Says Thank You to joed For This Useful Post:
Old 11-05-2014, 10:55 PM   #11
Rewards Points: 942
blue nut has to come off.. for plate to come off.. and faucet will come off..the end..
Old 11-06-2014, 06:55 AM   #12
Master Plumber
Javiles's Avatar
Rewards Points: 882
I have one better CALL A PLUMBER!!
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 11-06-2014, 08:19 AM   #13
DIY staff
Rewards Points: 4,534
Unscrew the water line for the spout and get it out of your way----then a deep socket can be used to undo that nut.
Most plumbers have a collection of the manufacturers installation wrenches---handy to have---
ben's plumbing (11-06-2014)
Old 11-06-2014, 11:26 AM   #14
Rewards Points: 20
You're so smart. I wish I would've thought of this!
Everyone else, thanks for the advice I will be attempting this tomorrow and will report back.
The Following 2 Users Say Thank You to zakiaziz For This Useful Post:
ben's plumbing (11-06-2014), oh'mike (11-06-2014)
Old 11-06-2014, 09:00 PM   #15
Master Plumber
Javiles's Avatar
Rewards Points: 882
LOL One pound of learning requires ten pounds of common sense to apply it. sorry to be blunt wrenches aren't for everyone. if your told three times on how to remove something and you have to keep asking maybe its best left to someone who can.
Outdoor Kitchen and garage faucet plumbing plumlost Plumbing 7 11-09-2014 09:01 AM
Kitchen Faucet Sprayer Does Not Work. Already Replaced Diverter. latenight Plumbing 13 08-12-2013 04:27 PM
Kitchen Faucet need2speed75 Plumbing 17 03-10-2013 10:25 AM
Kitchen Faucet - No hot water, just a trickle french69ssrs Plumbing 4 02-11-2013 01:14 PM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 08:28 AM
