How Can I Determine If I Have A Slow Concrete Slab Leak? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-22-2012, 08:18 AM   #1
Rewards Points: 588
How can I determine if I have a slow concrete slab leak?
I'm in Florida on a concrete slab and am in the process of a bathroom remodel. When I removed the toilet and the tile, I noticed it looked slightly damp around the flange, with a few micro roots growing up around the drain pvc, trying to reach through from underneath. I'm hoping this was just due to a bad wax seal at the flange from 16 years of use. Some of the water might have been from the fact that when I removed the toilet, a lot of water splashed on the floor as well. I put sheets of paper right on the surface of the concrete to see if there was any moisture after a few days on the paper and there was none.
Is this a correct assumption?
This morning, I turned off the icemaker and right before we left, I took a picture of the water meter reading. I'm thinking that if there was a slow leak somewhere, that this reading will be different when I get home from work tonight. I keep thinking that I may have a real slow drip drip leak somewhere. I guess i'm overly paranoid, but I want to be sure everything is right before I lay new tile.
Is **this** a good test?
noone is offline   Reply With Quote
Slab leak or not? loveyolife Plumbing 11 04-01-2012 01:25 AM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 02:45 PM
Help stone over concrete slab Johnnyquest Flooring 0 05-20-2011 03:36 PM
Removing concrete slab on 3rd floor bathroom NowItsShowtime Flooring 2 03-26-2009 02:17 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
