How Can Change The Shower Head Angle? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-26-2012, 03:12 PM   #1
Rewards Points: 16
How can I change the shower head angle?
I've installed a new shower enclosure but the chrome tube that connects the shower head to the pipe in the wall is the wrong angle. I haven't been able to find any shorter ones or one with more of an angle to direct the shower stream straight down (it is a narrow 32" wide shower stall). Thanks for the help in advance..
pennywise is offline   Reply With Quote
Old 04-26-2012, 03:32 PM   #2
Rewards Points: 150
Go to any big box store web site and search for shower head. You will see all different angles that are available. There are a whole bunch of on-line retailers with faucet in their name which have even more options. For a small shower you may want to go with what I call Bo Peep pipes.
goosebarry is offline   Reply With Quote
Old 04-26-2012, 08:28 PM   #3
Rewards Points: 582
try turning the shower arm or tube around.....should angle down further..
Old 04-27-2012, 03:19 PM   #4
Rewards Points: 150
That should have been shower arm.
BTW 32 inch wide shower would be considered standard.
Kerdi Shower Kit (48" x 48" Tray) For Desired 38" x 38" Neo Angle Shower JasonCA Kitchen & Bath Remodeling 4 04-08-2012 11:11 PM
Holes into tile don't match shower head! Oops1 Tiling, ceramics, marble 1 04-02-2011 06:37 PM
Threaded shower head connection too close to ceiling anygren Plumbing 6 10-11-2010 01:41 PM
Weak stream of water from shower head. SuperAkuma Plumbing 3 08-01-2008 05:49 PM
Shower Head Draining pinfordend Plumbing 2 05-04-2006 06:30 AM
