How To Build A Shower After Bathtub Removal? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2013, 12:15 PM   #16
Rewards Points: 4,796
I second (or third) the Schluter Kerdi kit recommendation.
jeffnc is offline   Reply With Quote
Old 01-21-2013, 02:04 PM   #17
Just wanted to update, The drain pipe run deep under the slab is 2 inches. I measured the wrong pipes last night. The main drain is 2 inches and there is a reducer to the rest of the drain that was run to the old tub. I will review all the posted links tonight while Im working. Thanks so far for the help. While Im here, any one have any ideas why that one wall is plywood and not left open like the other two walls? That wall backs up to my kitchen. Should I remove the plywood or just put the cement board over it?
Jn5685 is offline   Reply With Quote
Old 01-21-2013, 03:46 PM   #18
Roofmaster
Rewards Points: 2,172
Dont see a problem you've got 2 inch there, No?
Old 01-21-2013, 03:55 PM   #19
Shouldnt be.
Old 01-21-2013, 09:29 PM   #20
Doing it myself
Alan's Avatar
Rewards Points: 2,086
That 2" looks good.
I'd still go ahead and cut the floor enough to get the drain centered.
As to the plywood, that may be a shear wall. I wouldn't take it off ; besides it's probably more trouble than it's worth anyway to give your shower an extra 1/2".
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
TheEplumber (01-21-2013)
separate shower and bathtub drain 23675S Plumbing 6 03-06-2012 07:43 AM
what is best way to build shower stall ? dragonflysfo Tiling, ceramics, marble 2 11-20-2011 08:53 PM
Need to add shower to existing bathtub Tmack_5_0 Plumbing 4 04-05-2011 11:08 AM
Shower into a bathtub Adrienne331 Plumbing 5 08-05-2010 06:17 PM
convert bathtub to shower argos Plumbing 10 02-19-2008 11:53 PM
