How Bad To Dump Coffee Grounds In Kitchen Sink? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-25-2013, 07:02 PM   #16
Rewards Points: 1,062
Originally Posted by Ghostmaker View Post
It really depends on how your kitchen sink drain was run and if your dishwasher is also draining down that drain. The dishwasher hot water discharge will aid in keeping grease in control if your drain is made out of ABS or PVC plastic properly pitched the grounds will not have a problem. My go down it every night for 25 years. Never seen a blockage.
I figure the sewer rats may need some caffeine in their diet... I hear that they may get fat and lazy down there.
Also a great habit is to throw ice cubes down the disposal and run it. This helps keep the blades clean and sharp making it better to keep them caffinated rats out...
Have a good days and always a light heart... Later.
ya see??! I knew coffee cant be that bad!
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 07-25-2013, 07:10 PM   #17
Rewards Points: 150
I work at a small confectionary and about every week we have to dump draino down the sink because we flush grounds down the drain. If my coworkers would maybe let the water run for a minute to flush everything down. It builds up in the trap because they don't
romex1220 is offline   Reply With Quote
Old 07-26-2013, 05:33 AM   #18
Rewards Points: 1,216
Originally Posted by noquacks View Post
sand can not decompose. not the same analogy.
By the time it takes to decompose my drain is completely blocked so your statement is not totally true.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 07-26-2013, 11:49 AM   #19
Originally Posted by michaelson View Post
I put coffee grounds down the disposal while its running and have for years. Although my wife flushes lipstick tubes and tampons down the toilet so we might not be the best example.
LMAO WHAT?
Hardway is offline   Reply With Quote
Old 07-27-2013, 09:30 AM   #20
Rewards Points: 236
i have a reusable filter. i dump my grounds in the garbage. what little that remains = down the drain.
my wife used to put egg shells down the disposer. i tore her a new one !
Fix'n it is offline   Reply With Quote
Old 07-27-2013, 11:31 AM   #21
Rewards Points: 4,796
Ice cannot sharpen disposal blades.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
joecaption (07-28-2013)
Old 07-27-2013, 11:32 AM   #22
His statement is completely true. Sand cannot decompose.
Old 07-27-2013, 11:34 AM   #23
I've heard that putting eggshells down the disposal is fine. Maybe it has something to do with the scouring action of the tiny shell chips going through the drain after leaving the disposal. It's purely speculation - I don't know if it's good or bad.
Old 07-27-2013, 01:00 PM   #24
Come on people use your common sense if you have any. Use the disposal for what it's intended for, IE; Potato peels, left over veg's, cut up veg's from salad, pasta, beans, whatever. Should I stick a whole chicken in there ? Some without common sense will say yeah. Just use your head and run plenty of water while grinding and after you stop. DUH! That's all. Go ahead people that are offended let me have it.
KISS Principal.
Old 07-27-2013, 02:22 PM   #25
Rewards Points: 1,868
It doesn't sharpen the blades,disposals work by grinding the food scraps. What happens is it clears all the grooves in the impeller and body of the disposal. Most manuals recommend using about 2 cups of ice and some rock salt as a maintenance cleaning procedure.
Old 07-27-2013, 02:28 PM   #26
Sounds fine as cleaning - as sharpening, no.
Old 07-27-2013, 02:32 PM   #27
KISS Principal.
Unfortunately it's not that simple. Potato peels, for example, can be very thin and pass by blades without getting completely shredded. At the same time, they tend to catch food and clog, while clinging to the sides of the drain pipe sometimes. This is something things like coffee grounds and ice cannot do.
No, you should not stick a whole chicken in there, basically because it's physically impossible. Having said that, in some ways little chicken bones are better going down your drain than potato peels.
I'm not "offended", but what you're calling "common sense" (if we have any) doesn't always work, if your advice is what you call common sense.
Old 07-27-2013, 04:46 PM   #28
If I had a choice between putting chicken bones or potato peels down a garbage disposal the answer would be. Tune In.
Old 07-27-2013, 05:41 PM   #29
Plumber
TheEplumber's Avatar
Rewards Points: 564
I love people that use sinks and toilets as garbage pails- it's my bread & butter
The Following 4 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (07-27-2013), COLDIRON (07-28-2013), joecaption (07-28-2013), plumberinlaw (07-28-2013)
Old 07-28-2013, 07:12 PM   #30
Household Handyman
Rewards Points: 1,408
From experience: Putting anything down a sink depends on one factor: Lots of cold flushing water after placing "whatever" down a sink. One of the worst things I have found in pipes coming from the sinks in houses is just plain ole dishwasher soap. YEP! IMO--when then dishwasher drains/pumps into the system under the sink and "supposedly" goes on out to the municipal sewer or septic system the water/soap mixture enters the 2", or in some cases I have seen, 2 1/2" pipe the solution losses velocity and slows down, depending on the slope of the drain to the main drain. I've seen some of these that have so little slope it's a wonder that anything will move down this drain line. When the dishwasher solution is allowed to just lie that in the pipe the detergent WILL separate and build-up at the bottom area of the drain line. Another load of dishes and more build-up. I have actually had many cases of where my snake would not move but a few feet after entering a clean-out and had to cut the drain line somewhere to find out what the blockage was. I have found both 2" and 2 1/2" lines completely stopped up with a soapy residue that has become not so hard but gummy. I finally bought a drain line jetter attachment for my pressure washer to wash these out. One thing I was taught back in some Environmental Classes was that adding a large cupful (red Solo cup) of chunky dry dog food, and a lot of flushes, to a toilet system is good for cleaning out that "stuff" that builds up within the lines. Using smaller dry chunky dog food is good for kitchen sinks also, along with lots of water to push this through. I DO use these in my lines often, maybe monthly, and I have not had a stopped up line in this house.
coffee grounds bubbler Plumbing 19 06-07-2013 06:19 AM
How bad/unusual is it for a kitchen sink under window to be off-center? Iron Petunia Remodeling 17 11-21-2010 06:33 AM
Kitchen sink backing up to downstairs bathroom! macon215 Plumbing 1 09-25-2010 06:41 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Need help re-routing kitchen sink vent Fingers Plumbing 11 10-23-2009 03:17 PM
