How Bad To Dump Coffee Grounds In Kitchen Sink? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-24-2013, 09:05 PM   #1
Rewards Points: 1,062
How bad to dump coffee grounds in kitchen sink?
Curious- I dump in trash bag. But we were debating the seriousness of grounds as opposed to the very serious business of dumping animal fat, chicken bones, etc,etc. (heck, I dont even OWN a disposal!)
Any plumbers really see grounds (pun?) for coffee being a bad thing? Ever get a call to unclog a sink and have it be caused by coffee?
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 07-24-2013, 09:09 PM   #2
Rewards Points: 12,888
Would you pore sand down the drain?
Amounts to the same thing.
Use it as compost or put it in the trash can.
noquacks (07-25-2013)
Old 07-24-2013, 09:47 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 858
The best place to put those coffee grounds is in the garden....especially if you have clay soil....
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
Old 07-24-2013, 10:53 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 358
I've seen a lot worse go down a kitchen sink- really shouldn't be an issue if well flushed.
Think about composting instead though
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 07-24-2013, 11:21 PM   #5
Rewards Points: 6,652
Just throw them into your flower beds and garden. I toss mine in the trash, then rinse the little bit left in the filter, since I use a reusable filter in my coffee maker.
The Following User Says Thank You to gregzoll For This Useful Post:
Old 07-25-2013, 01:20 AM   #6
Rewards Points: 101
I put coffee grounds down the disposal while its running and have for years. Although my wife flushes lipstick tubes and tampons down the toilet so we might not be the best example.
michaelson is offline   Reply With Quote
Old 07-25-2013, 05:51 AM   #7
Rewards Points: 18
What seriously? Why would you do that?? Its not that hard to disposes of them and the toilet is probably the worst place for them.
jonn is offline   Reply With Quote
Old 07-25-2013, 06:20 AM   #8
raylo32's Avatar
Rewards Points: 1,226
See his other thread on this. Must be like an episode of Honey Boo Boo over there.
Live long and prosper.
raylo32 is online now   Reply With Quote
Old 07-25-2013, 07:26 AM   #9
Rewards Points: 1,214
If I was an unscrupulous Plumbing Contractor I would say sure dump them down the drain then give you my phone number and say give me a call if you ever have drain problems. Put them in the garden or on the lawn or in the trash.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 07-25-2013, 07:50 AM   #10
PoleCat's Avatar
Rewards Points: 1,646
Bannana peels through a disposal are the worst thing I have ever encountered. It was like a hunk of hickory wood in the pipe.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 07-25-2013, 03:30 PM   #11
firehawkmph's Avatar
Rewards Points: 1,800
Get a Kuerig coffee maker and you won't have to worry about it. http://www.keurig.com/
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 07-25-2013, 07:12 PM   #12
Rewards Points: 1,706
It really depends on how your kitchen sink drain was run and if your dishwasher is also draining down that drain. The dishwasher hot water discharge will aid in keeping grease in control if your drain is made out of ABS or PVC plastic properly pitched the grounds will not have a problem. My go down it every night for 25 years. Never seen a blockage.
I figure the sewer rats may need some caffeine in their diet... I hear that they may get fat and lazy down there.
Also a great habit is to throw ice cubes down the disposal and run it. This helps keep the blades clean and sharp making it better to keep them caffinated rats out...
Have a good days and always a light heart... Later.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Old 07-25-2013, 07:56 PM   #13
sand can not decompose. not the same analogy.
Old 07-25-2013, 07:57 PM   #14
yikes- you nee to have a talk with wife...LOL
Old 07-25-2013, 08:00 PM   #15
Mike Hawkins
too much $$ per cup. Also, very environmentally unfriendly. Plastic cups- toxic waste, maybe not in your drain, but in a land fill, or even likely floating eventually in the ocean.
But I have tried them and they do make tasty coffe.
coffee grounds bubbler Plumbing 19 06-07-2013 07:19 AM
How bad/unusual is it for a kitchen sink under window to be off-center? Iron Petunia Remodeling 17 11-21-2010 07:33 AM
Kitchen sink backing up to downstairs bathroom! macon215 Plumbing 1 09-25-2010 07:41 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 07:38 AM
Need help re-routing kitchen sink vent Fingers Plumbing 11 10-23-2009 04:17 PM
