How To Apply Teflon Tape On Thread? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-21-2012, 08:11 PM   #1
Rewards Points: 71
how to apply Teflon tape on thread?
How to apply Teflon tape on MIP male threaded pipe connector?
Is there drawing or graph showing the correct way to allow tape to lay correctly when screw into receptacle?
young707 is offline   Reply With Quote
Old 08-21-2012, 08:17 PM   #2
Rewards Points: 14,312
Hold fitting in your left hand threads facing up, hold the tape in the right hand, wind it in a clock wise directon. Make sure to keep tention on the tape.
You may have been trying to wind it in the wrong direction that's why the tape keeps getting pushed off the fitting.
If you use teflon pipe dope instead it's less likly to leak and easy to apply.
Old 08-21-2012, 08:33 PM   #3
Don't tape the first two threads, apply clockwise, and have at least 50% overlap.
hvac benny is offline   Reply With Quote
Old 08-21-2012, 08:41 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 914
Pretty much sums it up
Old 08-22-2012, 10:26 AM   #5
Rewards Points: 71
thank you
Old 08-22-2012, 08:16 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Same direction a fitting would thread on to it
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 08-22-2012, 10:24 PM   #7
I couldn't help but notice that he taped the first two starter threads.
Old 08-22-2012, 11:17 PM   #8
Plumber
Rewards Points: 914
I was taught that too in mech 1 class, but when it comes to plumbig it's not quite the issue
Old 08-23-2012, 06:08 AM   #9
Rewards Points: 1,216
To many people wrap it to much just wrap it 11/2 times to 2 times. No reason to wrap more it puts strain on the fittings.
COLDIRON is offline   Reply With Quote
Old 08-23-2012, 09:05 AM   #10
It's actually against the gas code in Canada (B149).
Old 08-23-2012, 03:36 PM   #11
Rewards Points: 1,548
Hold the pipe with the threaded end pointing forward, as if to screw it forward into a fitting that is in front of you.
Press the end of the Teflon tape on the top of the pipe, with the spool of tape to the left.
Bring the spool around under the pipe wrapping the pipe counterclockwise. Do 4-1/2 turns before cutting the tape.
Tape Showing cougar01 Drywall & Plaster 3 03-09-2011 04:21 PM
gas stove installation bigpun Appliances 3 01-13-2008 08:41 PM
Thread tape vs. Blue glue GT4NE1 Plumbing 9 07-10-2007 10:22 PM
Teflon tape adequate for spout diverter? darsunt Plumbing 1 06-05-2007 01:50 AM
