Old 08-09-2008, 01:16 PM   #1
how to adjust faucet handle stops?
replacing the trim on a roman at faucet,including handles. I noticed when we bought the house, the handles dont come to a stop the same. that is, one stops straight out from the faucet, the other is cockeyed; like 1-degrees.
someone said to adjust the valve or stemstop. not sure how to do that?
can someone explain or supply link? thanks,
THB
tarheelblue is offline   Reply With Quote
Old 08-09-2008, 03:13 PM   #2
the Musigician
DangerMouse's Avatar
hi. if there is a screw on the top, (may be under plastic cap, lift that part off with butter knife) simply undo it and lift the handle and rotate it to the next 'gear tooth' and see if that lines up. if the gears are stripped, you may have to replace the faucets.....
DM
Old 08-09-2008, 05:26 PM   #3
Send a message via AIM to Marlin
Try what MdangermouseM said. If that fails the only way to fix it is to access the underside and loosen and spin the whole valve.
Marlin is offline   Reply With Quote
Old 08-12-2008, 07:59 PM   #4
thanks folks. will look tonite.
Old 08-16-2008, 05:08 PM   #5
the handles are brass. I got them off by removing hex nut. I was assuming that there was something on the stem itslef.but is thepiece to adjust actually on the underside of handle?
Please help, Stuck cartridge,Moen single handle tub faucet, Woodpecker Plumbing 23 08-24-2010 03:42 PM
One Handle Shower Faucet GLASSMAN1 Plumbing 3 02-09-2008 04:08 AM
two handle shower faucet to single handle GLASSMAN1 Plumbing 2 01-31-2008 09:08 AM
Double Handle versus Single Handle kitchen faucet Lindahoney Plumbing 7 11-20-2007 10:36 AM
