How To Add Utility Sink And Washer Drain To Existing 4" - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2011, 11:09 PM   #1
How to add Utility Sink and Washer Drain to existing 4"
Hello,
I am trying to add a sink drain and also a washer box. The black lines in the photo show existing infrastructure. I would like to install a sink and washer box. I am assuming I will need to cut into the 3 to 4" section with the cleanout and install some sort of T with a 2" out to the drain for the sink and washer. Where do I put the P trap or traps and also where is it best to vent? Does the vent go between the washer and sink? I also have a 2" pipe on the other side of the wall that could be accessed overhead for a vent. Could someone please help draw this out for me? Thank you!!!
Tim
obriendigital is offline   Reply With Quote
Old 03-26-2011, 01:19 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 442
Something like this should work assuming that is a vent on the right and not a drain stack. What is it venting?
All fixtures need traps and vents. In this case the traps share a common (wet) vent. A clean out is in the new vent stack.
Old 03-26-2011, 04:40 AM   #3
Great thanks. The 2" to the right is for a sink in the bathroom in the next room and drains down and the vent goes straight upstairs. It is accesible so could use as a vent. Do I need a p trap on it or just tie in overhead?
Also do I put a p trap the washer box to the left in this drawing? The sink will have one as it came with it. By code the washer box needs to be 42" high. Any other type of fittings on this? I was reading about wye and avv and such. Thanks so much!
Old 03-26-2011, 09:26 AM   #4
you can't use a drain from upstairs for a vent downstairs. to use that pipe you'll have to run your new pipe upstairs next to the existing drain and tie your vent in above the sink. what does the pipe you're cutting into do upstairs? is it a drain for something as well?
yep you'll need a trap on the washer box and the sink. some people on here will tell you to use an aav, but i believe if you're going thru all this work and opening up the wall you might as well do it right. some municipalities do not allow them also.
the_man is offline   Reply With Quote
Old 03-26-2011, 09:52 AM   #5
Thanks for the reply. The 2" pipe is actually for a bathroom downstairs(on other side of wall) that drains into the system under the concrete. It then goes up stairs and is a vent, so I am assuming I can tie into this pipe as a vent?
My basement is partly unfinished, so I have the luxury of doing this all the right way.
With the amount of water coming from the washerbox, would it make sense to put the sink all the way to the right, ptrape, vent, then washer box, ptrap?
I just want to make sure there is no backflow into the sink.
Thanks,
Tim
Old 03-26-2011, 10:14 AM   #6
I took a few photos to illustrate the project. I checked the 2" pipe further today and it is draining from a sink upstairs, so that won't work i guess for a vent? correct? this is the photo with the beer by it
I also have a photo of the new cleanout and T to put into the 4" to 3" stack. Is this ok? The 2" will run around the corner to the sink and washer.
The other photo is ultimately where I want the sink and washer.
Lastly, there are a couple photos of the stack towards the ceiling, it looks like the left part of the Y is the main vent, can I tie into that with a saddle to 2" then over my wall to work as a vent?
How to add Utility Sink and Washer Drain to existing 4"-photo1.jpg   How to add Utility Sink and Washer Drain to existing 4"-photo2p.jpg   How to add Utility Sink and Washer Drain to existing 4"-3photo.jpg   How to add Utility Sink and Washer Drain to existing 4"-4photo.jpg   How to add Utility Sink and Washer Drain to existing 4"-5photo.jpg
Old 03-26-2011, 10:19 AM   #7
Thanks,
Tim
if that pipe is just a vent, you're in good shape. a 2" pipe is enough for a washer drain, sink placement won't matter. the way eplumber drew it allows the sink to wet vent, so only one vent pipe is needed. in my code, you have up to 5 feet for 2" and 3.5 feet for 1 1/2" away from that vent without having to run another vent (trap arm length) so be careful with the placement
Old 03-26-2011, 10:23 AM   #8
I made some drawings on the photos if this helps.
Thanks!
How to add Utility Sink and Washer Drain to existing 4"-plumbing3.jpg   How to add Utility Sink and Washer Drain to existing 4"-plubming4.jpg   How to add Utility Sink and Washer Drain to existing 4"-final-plumbing.jpg
Old 03-26-2011, 10:26 AM   #9
Thanks for the reply! Did you see my other post, the darn 2" is actually a drain for a sink upstairs, I was wrong. So do I go into the big 3" for the vent? I am confident it's the main house vent.
Old 03-26-2011, 07:39 PM   #10
Plumber
Rewards Points: 442
I doubt the 3" is a vent. It probably is a drain for a toilet.
Can two washers drain into one utility sink? mcru Plumbing 6 07-26-2010 09:23 PM
After Snaking, Basement floor drain and utility sink still Bubbling & Backup bikermark1 Plumbing 2 07-22-2010 01:14 PM
Washer drain pipe and adding a utility sink lubyone1 Plumbing 5 07-09-2010 11:56 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
utility sink, washer drain simon Plumbing 4 11-14-2007 08:30 PM
