-   -   How to add a laundry drain to existing wall (http://www.diychatroom.com/f7/how-add-laundry-drain-existing-wall-179328/)
Daugela 05-11-2013 06:33 PM
I'm sure there's a simple answer, but for the life of me, I can't figure this out.
Converting my garage into an additional living space. Adding concrete to the garage to level it out with the existing home with all new drains under the concrete.
Adding a laundry room to the corner of the existing garage. When I route down the washing machine drain to the bottom plate, how do I get it routed beneath the concrete slab? It's not like I'm building this new wall over the new concrete floor which I could plumb the drain up from.
jagans 05-11-2013 07:00 PM
I dont understand the question. Pictures would help.
Daugela 05-11-2013 07:30 PM
I don't have any pics since I haven't started the project yet.
Normally, when you build a home on a slab, you lay your plumbing and then pour the concrete. Some of the plumbing drains come up through your bottom plate and into the walls between the studs.
I'm adding a laundry room to an existing wall that doesn't have any drains to tie into. My closest drain would be in the adjacent room. Therefore, the drain I'm going to be putting into the laundry room will be run under the slab.
How do I plumb the drain from the concrete floor up into the wall for the washing machine?
TheEplumber 05-11-2013 07:47 PM
199 Attachment(s)
Sounds like you need to cut the slab, trench and lay the pipe, Chip out the stem wall if needed.
Daugela 05-11-2013 07:54 PM
Perfect. This is what I was looking for. "Chip" the stem wall if needed. Makes sense. Yes cut the slab and trench. Wasn't sure about how to route up. Chip away makes sense. Thanks!
