How To Add Air To Pressure Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-04-2012, 09:05 AM   #1
How to add air to pressure tank
I have a bladder-less tank (Amtrol RT42TT) with a Braukmann Auotomatic airvent. There are 1-1/4" fittings at the bottom. It is a submersible pump with a check valve.
The system has started short cycling and I have inspected all fittings and tested the tank and there are no leaks. My dilemma is that there is no air intake on the tank at the pressure switch or on the check valve.... Any advice is appreciated.
caseyatbat is offline   Reply With Quote
Tags
air , pressure tank , water
Well tank has no pressure -- PLEASE HELP supitch15 Plumbing 15 02-21-2013 09:00 PM
New Well, Pump & Pressure Tank Design Daneel Plumbing 0 06-07-2011 03:28 PM
Pressure pump cutting in after several minutes of tank emptying Trevor167 Plumbing 2 05-23-2011 08:06 PM
A shared well - do I need a pressure tank upinsmoke Plumbing 9 05-29-2010 03:16 AM
pressure tank problem? steel Plumbing 14 07-03-2008 02:06 PM
