Household Water Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-28-2010, 03:23 PM   #1
household water tank
I have a sand point now used for watering garden etc it pumps into a 50 gallon steel Duro tank as it has not been used much in last few years perhaps the bladder a problem when used pump kickcs in kicks out rapidly not very much output does bladder need help? The tank has input on bottom output on bottom on the side there is a pressur guage 1/2 way up tank top of tank there is a screw plug
drums is offline   Reply With Quote
Old 03-28-2010, 07:19 PM   #2
Rewards Points: 1,532
There may be too much water and not enough air in the tank.
Try this. Turn off the well pump, empty all the water from the tank with the air valve open, close the air valve, and turn the pump back on.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Well Water Pressure Tank for Air? Reilley Plumbing 8 02-20-2009 12:53 PM
Solar hot water + tankless gp_wa Plumbing 3 08-27-2008 12:48 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Hot water heater expansion tank? rjniles Plumbing 3 06-21-2008 10:53 AM
