House Water Pressure Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-23-2011, 09:57 AM   #1
House water pressure issue
I have a loss of pressure in all my faucets in the house except the laundry sink in the basement has plenty of pressure.This started a week ago and find it odd that pressure is good in the basement but not in the rest of the house.I have a reading of 75 psi at the pressure tank that does not change while the water is running.I have a 1.5cft softener,chemical feed pump system and a 10" sediment cartridge filter installed.I thought to check the cartridge but wouldn't that effect all outlets?Thewater also has a high tds reading of 820 ppm,not sure if that could effect any valves.Any advice would be helpful,thanks.
Jim Schueler is offline   Reply With Quote
Old 02-23-2011, 10:25 AM   #2
Water Treatment
Rewards Points: 898
Have you checked the screens at the faucets? The laundry tub normally does not have one.
Akpsdvan is offline   Reply With Quote
Old 02-23-2011, 11:04 AM   #3
Yes I have checked the screens and they were clean
Old 02-23-2011, 11:23 AM   #4
Water Treatment
Rewards Points: 898
All of the faucets after the water treatment?
Laundry tub is before or after the treatment?
You might get a replacement line like what is between the angle stops and one of the sinks , close off the angle stop and put the extra line on the angle stop and go into a bucket and see what kind of pressure you have.
Replaced water heater, still smelling sulfur in hot water & Low water pressure aminus21 Plumbing 2 07-21-2010 04:40 PM
Installing Sprinklers appear to have caused Water Pressure to DRASTICALLY increase geminigirl Plumbing 3 11-12-2009 12:04 PM
Replaced PT Valve but now have water pressure issue krisdiy Plumbing 3 09-17-2009 01:42 PM
Low Hot Water Pressure jifisher Plumbing 10 07-27-2009 06:48 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
