Old 06-01-2010, 08:54 AM   #1
House Main Drain Leaking under Concrete
Hi all, I'm in a house build circa 1896, and (probably for a few months; I just arrived) water is seeping slowly up out of the concrete in the basement. That room in the basement has a concrete floor, and in the corner there is a 5'x8x'10" concrete slab, and going into that slab are two large cast-iron drainpipes and one small drainpipe. The seepage is on top of the raised slab and near its base, and I think it is caused by one or more leaks inside the raised slab. My guess is the main sewer line for the house turns either in or right under the slab and goes out to the street, perhaps 20" under the water line. I know this is beyond my limits for a DIY project. Is the thing to do to get the pipes above the slab detached by a plumber and then have the slab entirely removed by a concrete cutting company and then to have a plumber re-do all of the plumbing in PVC? Or to have them cut and, if they find the leak, stop cutting once they've removed the concrete sections the leak was in? (And if they don't, cut it all?) Or something else? My concerns are (1) having a reliable sewer line, (2) being sure the concrete cutting company doesn't make more work than needs to be done for a plumber, and (3) keeping costs down. Thank you for any thoughts. Kind Regards, Tom738 PS -- If anyone knows any good plumbers or concrete cutters who work in lower Westchester, I could use a recommendation or two.
Tom738 is offline   Reply With Quote
tub drain off by 1/2", worth busting concrete? thezs Plumbing 12 12-30-2012 01:04 PM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 04:55 PM
Weird wiring in house fdmillion Electrical 7 02-26-2010 01:57 AM
Running condensation drain into house drain log_doc_rob HVAC 2 09-07-2009 10:46 AM
Water main Elbow at House anagy007 Plumbing 4 12-17-2007 04:34 PM
