House Drain Concern - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-20-2017, 02:12 PM   #1
Rewards Points: 8
House Drain Concern
My fiancee and I moved into a house a few months ago - an older home (about 95 years old) but almost entirely renovated. My concern is in the basement - the drain (4" PVC) connects to a cast iron pipe and pitches down, seemingly properly, into the floor in the direction of two clean-out plugs. Next to the clean-outs there is a cast iron pipe (also 4") that comes out from the floor and turns 90 degrees into the wall going toward the street (where the sewer pipe would go). The floor is also not near level (slopes, hills, valleys, etc) and has several areas that sound hollow when lightly hit.
Common sense tells me that the drain (which we have only had one problem with - construction debris clog, since cleared out) is fine and that "extra" pipe is a relic of something from years past, but that, combined with the uneven floor is a concern.
Any thoughts?
mtvernon is offline   Reply With Quote
Old 02-20-2017, 02:39 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 568
Re: House Drain Concern
Something like one of these?
Old 02-20-2017, 02:42 PM   #3
Rewards Points: 8
I have a photo but apparently I cannot post links here at the moment -
Old 02-20-2017, 02:43 PM   #4
Rewards Points: 8
Old 02-20-2017, 02:47 PM   #5
Rewards Points: 8
OK - I was able to create an album on here- the two photos show what I am trying to explain. In the PVC photo that cast pipe on the floor goes into the slab a few feet away and lines up pretty well with those cleanout plugs (the red ones) in the direction of the street. That other pope is the concern.
Old 02-20-2017, 07:29 PM   #6
Rewards Points: 252
If it's not leaking, backing up or smells of sewage in that area, I would just leave everything alone. Jmho.
jmon is online now   Reply With Quote
Old 02-20-2017, 07:42 PM   #7
Rewards Points: 252
The other pipe looks fine to me. The 4 in looks like a toilet, and the 2in looks like a shower/wet vent that was patched into the old cast iron.
I'm assuming you are concerned with the concrete floor sloping/sounding hollow when you knock on it? Can't really tell from the pics. By the discoloration, it looks like it was broken up and patched at some point in that area or it's leaking underneath the slab Idk. Does it feel damp in that area?
If it were leaking, shifted, broken or backing up you would definitely smell it. Unless I'm just not following what your concern really is. Remember you are dealing with an almost 100 year old house and plumbing. If it's not broken and everything is draining fine leave it alone. Jmho.
The hollow sound and sloping could just be it wasn't back filled to level or they followed the current pitch of the basement. Just a thought.
Wish I could help you out more with suggestions. Please wait for the plumbers to respond. Thank you.
To Plug or Not to Plug Secondary Condensate Drains Pestle HVAC 1 08-11-2015 07:14 PM
Proper Slope for Sump/Gutter Drain dankoos Plumbing 0 05-06-2013 12:59 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
Running condensation drain into house drain log_doc_rob HVAC 2 09-07-2009 09:46 AM
sewer backup and stench jayhill Plumbing 12 08-13-2008 11:06 PM
